240v To Sub Panel? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-15-2010, 11:49 PM   #1
240v to sub panel?
I would like to install a sub panel in my garage. I have installed 120v subpanel before. I would like to use a already existing 240 wiring from the house to the garage I would like to keep a 240 circuit and some 120's. My question is instead of running the black wire from one post to the other(what i gather is bonding). Can I run the black wire to one post and the red wire to the other? Or? by the way the sub panel has no main breaker, do I have to have a main? Pretty much what im asking is how do i do it correctly? Thank you for your time.
rsclark67 is offline   Reply With Quote
Old 02-15-2010, 11:59 PM   #2
" Euro " electrician
frenchelectrican's Avatar
I will make it very simple question here .,,
Is your garage is attached or detached ??
The reason why I ask due there is big diffrence on the code { regulations } you can do with subpanel in the attached garage and deattached garage.
To make it worst ., the detached garage only can allow one MWBC { multi wire branch circuit } the attached garage is unlimited.
Once we know the question then we will go from there.
Merci,Marc
Old 02-16-2010, 11:07 AM   #3
Rewards Points: 2,800
You may have in the past wired up a 120/240 volt subpanel for 120 volt circuits only where you connected the hot (black) feed wire to both hot posts or lugs.
For 240 volts you must connect one hot feed (black) to just one post and connect the other hot feed (red, may be white for 240 volt only feeds) to the other post.
A subpanel does not need a master breaker. Its feed will be from a breaker in the main panel (breaker pair for 240 and 120/240 volt feeds).
Meaning: you may not have one cable going between the (separate) buildings for the 120 volt loads and another cable to feed the 240 volt loads.
120/240 volt circuit -- another name for multiwire branch circuit with two hots (240 volts) and one neutral.
Bonding -- Electrically connecting via metal to metal contact, via jumper wire, etc. two or more objects for example the ground bus bar (terminal strip) to the panel frame (can; housing).
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 02-16-2010, 02:19 PM   #4
thank you. I do have an attached garage. but im only running only one wire to the subpanel(240). So the wire question(hots) is answered. Now if I do this Ican run both a 240 and 120 from that box ?
Old 02-16-2010, 02:55 PM   #5
Licensed Pro
As long as the new subpanel is fed with 4 wires (H, H, N, G) then you will have 120/240V available.
Old 02-16-2010, 03:03 PM   #6
Thank you for the info. All my questions are answered for now. When I am finished with this thread is there a way to signify that? Or does it not matter?
Old 02-16-2010, 09:20 PM   #7
Rewards Points: 1,016
Nope - nothing needed to close a thread, your thank you works great.
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
240v sub panel hook up with no neutral ut74 Electrical 7 03-07-2008 07:30 PM
