240v Motor - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-20-2010, 08:22 PM   #16
Here is a photo if it helps
G'day guys,
I just pulled the cover off my motor which has the same model number.
i have attached a photo of the connections.
The grey wires running off to the right go to the overload switch.
Will_Turner is offline   Reply With Quote
Old 02-20-2010, 09:30 PM   #17
Thumbs up
reply to 240v motor
hi will thanks heeps for the motor pics thats my model alright
there is just one thing more iwould like to ask. the capacitor wires
it looks like there is two orange wires and two mauve wires
the orange wires i can see ok but the mauve iam not shore of it looks like
one is connected to the first bolt z1 and the other is connected to the
second bolt A1 is this right. i will wait for your reply many thanks again
regards
outback4u
outback4u is offline   Reply With Quote
Old 02-20-2010, 09:36 PM   #18
will i have sent you a reply to you motor pic. but as iam new at this too
i think i did it wrong. but no worrys the reply is at the bottom of your pic
you sent thanks sport
outback4u
Old 02-20-2010, 10:10 PM   #19
reply to 240v motor pics
thanks will i have left a reply at the bottom of your pic
outback4u
Old 02-21-2010, 01:43 AM   #20
regards
outback4u
The two purple wires from the starting capacitor are connected to the z1 and 5 terminals
Will
Old 02-21-2010, 06:40 PM   #21
Thumbs up
240v motor reply to will
Will
will turner. you have just solved a problem that i have been trying to solve
for mths. thumbs up sport and many thanks.
are you from oze i only asked becaurse the motor was made here 40yrs ago
i purchased it back then and this is the first problem i have had with it
catch ya
outback4u
Old 02-21-2010, 06:56 PM   #22
outback4u
Yeah, I am in Warwick in sunny QLD.
It was just luck I found your post.
My motor is misbehaving and so I am pulling it apart. It is on an old compressor which my grandfather has had for a long time. The motor has started to arc from some of the contacts in the back to the housing when the compressor turns off and this is tripping the earth leakage. I am not really sure what is wrong so I think I will go and have a look in some textbooks, improve my motor theory and then try and work out the issue.
I am glad however, that as a side issue, I was able to solve your problem.
Have a good one, Will
Old 02-21-2010, 11:05 PM   #23
240v motor reply
your points at the rear may be worn or just need fileing also when you
check the winding araldite them before you put the motor back together
let the araldite dry for a couple of days this will give you a nother 20yrs
lets now how you go also check the bearings if they are worn this puts
strain on your points when shutting down
bye the way iam bob from bega nsw
outback4u nickname
Do you think a tool running at 240v works better than at 120v? Piedmont Electrical 39 07-03-2009 09:50 PM
Oiling Trane XB1000 AC Fan Motor Build HVAC 5 06-19-2009 04:05 PM
Motor control wiring problem dgr68 Electrical 8 01-04-2009 05:13 PM
Air Compressor Motor Hums, Trips Breaker pointertopica HVAC 10 12-02-2008 10:20 PM
Replacing a Condenser Fan Motor thothtp HVAC 5 06-08-2008 06:30 PM
