240 Wall Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 11-20-2010, 12:46 PM   #1
240 wall switch
I have a electric room heater that hangs on the wall, it runs on 240 but it is low amps. only 15 for the breaker and the wiring is #12. There is no turn off switch on the hearter and I would like to be able to install a wall switch so it can be turned off and on. It is used for a bathroom in my basement which is not finished and is cool in the winter time.
Every switch that I find at home depot etc. shows that there for 120 volt.
Thanks in advance and any help would be deeply appericated
ecn100 is offline   Reply With Quote
Old 11-20-2010, 01:12 PM   #2
Rewards Points: 150
you want a "two-pole" or "double-pole" switch. DPST is the electronics-oriented name for it. It will have four terminals but is not the same as a "4-way" switch.
You could very well just install a line-voltage thermostat. Most of them have an OFF option.
emolatur is offline   Reply With Quote
Old 11-20-2010, 05:07 PM   #3
I=E/R
a7ecorsair's Avatar
Something like this:
http://www.homedepot.com/Building-Ma...atalogId=10053
This would be an easy installation if you have access to the wiring. Mount this on the wall about 5' high using a plastic box, connect your incoming 240 and run a line to the heater.
a7ecorsair is offline   Reply With Quote
Old 11-20-2010, 07:37 PM   #4
Rewards Points: 150
"This would be an easy installation if you have access to the wiring."
And if he doesn't... then the switch isn't an option either.
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Wiring an Intermatic Wall Timer in a three way switch aitutaki98 Electrical 6 07-23-2011 11:43 AM
Help with four way switch jwetsit Electrical 3 05-04-2010 06:05 AM
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
Electrical outlet controlled by a wall switch? rinlo Electrical 14 12-28-2008 10:30 PM
