240 Volt Circuit Question - Electrical - DIY Chatroom Home Improvement Forum
Old 02-28-2010, 10:13 AM   #1
Question
240 volt circuit question
I wanna hook a plasma cutter up in my home shop using a twistlock plug(NEMA L6-30R) on a 30 amp double pole breaker. I would like to have more than one location to plug the plasma cutter in i.e. multiple receptacles. My question is can I hook them up on the the same circuit in series like 120v or do they have to be on seperate breakers?
dukeofsolidsrfc is offline   Reply With Quote
Old 02-28-2010, 10:45 AM   #2
Rewards Points: 308
Yes, You can install more than one 220 volt receptacle to one 2 pole 30 amp breaker. You must use 30 amp receptacles and #10 wire.
Old 02-28-2010, 10:46 AM   #3
Civil Engineer
Rewards Points: 5,246
AC household plugs are never wired in series, they are wired in parallel. They are daisychained together, however this is NOT series wiring. Electricians on this forum have stated on a number of occasions that there is no limit to the number of plugs that can be daisychained on a single circuit. This was stated in regard to standard 15 or 20 amp outlets, however I know of no clause in the NEC that prohibits daisychaining of higher amperage outlets, perhaps others can cite a section that specifically addresses the issue.
Old 02-28-2010, 11:11 AM   #4
Idiot Emeritus
Rewards Points: 80
You can put as many receptacles as you want on one circuit. No limit.
As stated above, all receptacles must be 30 amp, and wire must be #10 or larger.
Rob
micromind is offline   Reply With Quote
Old 02-28-2010, 11:53 AM   #5
Cool
Yeah that's what I meant.
Thanks for the help.
Old 02-28-2010, 01:27 PM   #6
Rewards Points: 1,016
I have two 240v recepts on the one circuit/breaker - one on either side of my workshop, so I can readily move my welder around.
Old 02-28-2010, 02:00 PM   #7
You can but you will have to pigtail the wiring at the receptacles so that you only have one wire per terminal on the receptacle - 30 Amp receptacles terminals are not rated for more than one wire per terminal.
muckusmc is offline   Reply With Quote
GFI/GFCI Question with a certain appliance. Wolfies167 Electrical 7 01-13-2010 08:28 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
short circuit question bryan1282 Electrical 1 10-05-2009 05:14 PM
Circuit Size Question techinstructor Electrical 12 06-28-2009 08:24 AM
Wiring Design Considerations Question tjandt Electrical 6 09-26-2006 05:44 AM
