240 Plug For Ranges - Electrical - DIY Chatroom Home Improvement Forum
Old 11-15-2010, 08:30 AM   #1
240 plug for ranges
what type should I use?
TimR is offline   Reply With Quote
Old 11-15-2010, 08:56 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,470
Huh,..?? The 1 that Fits the application...
Old 11-15-2010, 09:05 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
Ranges do not come with cords. You h ave to match the cord to the circuit/receptacle.
A "standard" household electric range receptacle is a NEMA 14-50R.
This is a 120/240v-50a 4-wire grounding receptacle.
Old 11-15-2010, 02:31 PM   #4
Rewards Points: 256
There are two types designed for ranges. One is 3 prong one is four.
Use the four prong. Its the only code-compliant option for a new circuit and its safer.
If you are replacing an existing one do not change from 3 to four prong unless you run a ground wire: which you should do if you have acess.
michaelcherr is offline   Reply With Quote
Old 11-15-2010, 02:32 PM   #5
Rewards Points: 256
Replacement plug for an old box freezer brich Electrical 1 05-11-2010 06:44 AM
removed old romex (added new wire) and added a plug doesn't work now? Limit54 Electrical 9 11-08-2009 09:03 PM
Unpolarised US Type 2 Plug to UK Plug. razorcut Electrical 19 05-18-2009 09:49 AM
20 amp plug MikeyP Electrical 6 01-03-2009 09:04 PM
New plug for toaster oven? mike720 Electrical 3 11-23-2008 07:44 PM
