240 Amp Wire To Stove-basement - Electrical - DIY Chatroom Home Improvement Forum
Old 01-17-2010, 01:14 PM   #1
240 amp wire to stove-basement
Hi to all would like suggestions on running wire from panel in garage to jct. box outside to oven in basement, alredy have wire in basement.
Thanks !
mxtr is offline   Reply With Quote
Old 01-17-2010, 03:25 PM   #2
Remodeling Contractor
Check what size you stove needs. Most are 50Amp so you need a 6/3 cable.
Old 01-17-2010, 03:28 PM   #3
please get a book on basic electrical circuitry and wiring and read it. Pretty sure your stove is not 240amps
Old 01-17-2010, 03:36 PM   #4
Gee... a type.. surely he meant 240 VOLTS>>..
Old 01-17-2010, 03:43 PM   #5
maybe...hopeso
Old 01-17-2010, 03:52 PM   #6
" Euro " electrician
frenchelectrican's Avatar
Thanks !
What are you plan to do with outside part that will be in conduit or use the SER cable ? if run in conduit it will look little more neater.
Keep in your mind as one of the poster here mention you will need 6-3W/G as the code mention you need 4 conductor set up and 4 wire cord from the receptale to the stove.
The #6's you need 50 amp breaker for it while if you go with #8 you will need 40 amp breaker
Merci,Marc
Old 01-17-2010, 06:19 PM   #7
An old Tradesmen
Rewards Points: 2,904
If that isn't a typo.
Then he has a BIG 12 burner stove with 2 ovens a rotisserie and a smoker.
Old 01-17-2010, 06:23 PM   #8
Inspector/Instructor
codeone's Avatar
Not even in a commercial configuration.
codeone is offline   Reply With Quote
Old 01-17-2010, 06:51 PM   #9
An old Tradesmen
LOL... I was being sarcastic.
Old 01-17-2010, 08:14 PM   #10
Thanks for the feedback, as you can tell I am no electrician - I'm just trying to get things done with very little experience in this matter I will note all responses and work from there. The wire size is right @6-3w/g and breaker size is right as I understand, the line will be buried in PVC.
Thanks Again, Mxtr
Old 01-17-2010, 08:16 PM   #11
Reg NMB wire can't be buried in conduit
You need wire rated for underground use or indivual THWN wire
Overheated Wire Connections In Stove Top chef Electrical 5 09-06-2008 06:35 AM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
Stove Top wire capt2 Electrical 8 10-05-2007 01:41 PM
3 wire connection for new kitchen stove rjniles Electrical 4 09-13-2007 12:59 AM
