240 To 120 Range Outlet Conversion - Electrical - DIY Chatroom Home Improvement Forum
Old 01-10-2010, 09:55 PM   #1
240 to 120 range outlet conversion
I just converted my kitchen from an electric range to an all gas range. The installation directions call for plugging the new range into a dedicated 120V grounded outlet to drive the clock and controls. To avoid running additional lines, I would like to take the existing run that used to power the 240V three pronged outlet with 40a breakers and use it for a new 120V GROUNDED outlet protected by a 20a breaker. Since this old work doesn't have a dedicated ground, would it be appropriate to use one of the old "hot" wires and turn it into a ground? Doing this would require a pigtail in the breaker box... and that doesn't seem right. Bottom line, what should I do to make this right? Thanks!
Cousteau135 is offline   Reply With Quote
Old 01-10-2010, 10:01 PM   #2
What size wires are ging to the stove & how many ?
Usually you would install a 20a breaker, pigtail #12 wires & connect
You need a hot, white neutral & a ground
And install a normal outlet at the other end
Might also consider leaving it & just running a 20a outlet
But most people do not change from a gas stove back to electric
Old 01-10-2010, 11:10 PM   #3
I'm really not sure of the size (either a #8 or #6) but the 2 hot wires of the 3 from the box are protected by dual 40 amp breakers.
Correct me if I'm wrong, due to existing wire length, the ground and neutral will need to be on the same bar. As I understand it, that is acceptable... correct?
Old 01-11-2010, 07:53 AM   #4
If the wires go back to a Main panel then the ground & nuetrals can be mixed
If they go to a sub panel then they are on seperate bars & neutral must be isolated from the case
Old 01-11-2010, 07:56 AM   #5
Inspector/Instructor
codeone's Avatar
Is your wiring an SE cable with a bare neutral?
codeone is offline   Reply With Quote
Old 01-11-2010, 01:20 PM   #6
Thanks for the replies. Nope, it isn't SE and it is going back to the main breaker panel.
Old 01-11-2010, 02:17 PM   #7
Rewards Points: 614
Three wires. What three colors? Forget the connections for now.
What type of cable is it? Is it a conduit with wires inside it?
3 wires is exactly what you need for a 20 amp circuit. 1-Hot, 1-Neutral and 1-ground. So tell us what type of cable you have or if you have conduit and what color wires you have. We may be able to use this circuit as is.
Electrical Outlet Conversion 230/110 mcbuster Electrical 11 07-20-2009 01:03 PM
Replace Range Outlet Suncrest79 Electrical 22 04-14-2009 11:32 PM
Dryer outlet vs. Range outlet cindakay Electrical 24 04-13-2009 06:01 PM
Range outlet pushes oven too far from wall givemeabreak Electrical 8 08-19-2008 12:14 AM
changing a range outlet or plug marty7 Electrical 9 12-17-2007 10:11 PM
