220v Relay - Electrical - DIY Chatroom Home Improvement Forum
Old 07-26-2014, 02:26 PM   #1
Rewards Points: 640
220v relay
So I have an application which uses a 220v relay switch, with a 220v coil. The only thing I need to confirm, is that the coil has two contacts. Normally, when I use a 110v coil, it's obvious that you use the line and neutral wires (black and white wires) to power the coil. With the 220v coil, are you using the 2 line wires (red and black in my situation)? I'm thinking you must since if you used one hot wire, and the neutral, you only have the 110v.
taylorjm is offline   Reply With Quote
Old 07-26-2014, 03:11 PM   #2
Rewards Points: 29
You are correct. The alternating phases are what make 240v out of 2- 120v lines.
Sent from my iPhone using diychatroom.com
Ben25 is offline   Reply With Quote
Old 07-26-2014, 04:05 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 17,880
See those 3 wires coming to your house?
2 Of them are 120Vac each....180 deg out of phase. The other is neutral.
Neut to either wire gives you 120Vac....but hot to hot...240Vac...
With that said.....it's Saturday....it's hot....It's beer time....
Old 08-02-2014, 08:24 PM   #4
Rewards Points: 640
So, another related question. For the same 220v relay, if I wanted to cut power to the relay, can I put a switch in one of the hot coil legs? If I do that, is it ok for the switch to be rated for 20a 125v since it's only one leg?
Old 08-02-2014, 08:26 PM   #5
JOATMON
ddawg16's Avatar
No, it needs to be rated for 240 vac.
Old 08-02-2014, 08:40 PM   #6
Rewards Points: 640
Ok. Not that I'm doubting you, but only because I like to learn. So, since the switch is only interrupting one hot leg, it's not switching a neutral, or the other hot, how does the switch know it's 240v?
Actually, now that I looked at it, the switch I was going to use is rated at 20a 125v or 15a 250v. I would have though the amps would have been cut in half for the 250v. Does that sound ok?
Old 08-02-2014, 10:21 PM   #7
Rewards Points: 1,052
It would work, as breaking one leg breaks the circuit; but its not okay. When you turn the switch off there will still be 120v at the relay. Everyone, probably including you, will think it is dead and will be unpleasantly surprised.
Think of it as putting the switch on the 120v neutral instead of on the hot; it works, but is not safe.
To answer your second question; a 240v switch is across both legs.
Toller is offline   Reply With Quote
Old 08-03-2014, 06:25 AM   #8
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by Toller
It would work, as breaking one leg breaks the circuit; but its not okay. When you turn the switch off there will still be 120v at the relay. Everyone, probably including you, will think it is dead and will be unpleasantly surprised. Think of it as putting the switch on the 120v neutral instead of on the hot; it works, but is not safe. To answer your second question; a 240v switch is across both legs.
A controller does not have to break both legs, but the disconnect does.
The Following User Says Thank You to stickboy1375 For This Useful Post:
mpoulton (08-04-2014)
Old 08-03-2014, 06:29 PM   #9
Rewards Points: 640
So is a relay considered a controller?
Old 08-04-2014, 12:20 PM   #10
Semi-Pro Electro-Geek
Rewards Points: 3,652
The voltage across the switch is 240V when it's open. You are not switching "one" hot leg, you are opening a 240V circuit.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 08-04-2014, 02:31 PM   #11
Rewards Points: 640
After thinking about it some more, I see what you mean. Once the circuit is complete, there is 240 running through that single wire I was going to cut, so the switch would need to be rated to handle that load.
Wiring a Honeywell RA89A Relay shawnmd HVAC 9 10-17-2016 06:52 PM
dayton 2pole 220v dedicated relay cuemaker Electrical 3 04-03-2013 03:52 PM
Isolation Relay michael_h HVAC 0 01-14-2013 10:41 PM
RIBU1C Relay in Residential theatretch85 Electrical 6 11-13-2012 10:48 AM
220V & 110V outlets rickinnocal Electrical 21 05-13-2011 01:16 PM
