220V | Question About The Two Hot Wires. - Electrical - DIY Chatroom Home Improvement Forum
Old 11-26-2010, 06:49 PM   #1
Question
Hello all!
I just replaced my external 220v outlet, with an internal (in-wall) version; I rewired as it was before, black on the left prong, ground on the middle, and red on the right prong. But now I'm wondering if it matters where the two hot wires attached to. On my other outlet, I simply have two red wires attached to the left and right prongs, with the ground in the center.
Thanks,
V
suprvee is offline   Reply With Quote
Old 11-26-2010, 07:00 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
the 2 hots are interchangeable
Old 11-26-2010, 07:13 PM   #3
Electrical Contractor
kbsparky's Avatar
FYI -- the outlet pictured is a non-grounding receptacle. NEMA 10-50R has 2 hots, and a neutral. All 3 wires are considered "current carrying" conductors.
Commonly used on older range circuits, where the frame of the appliance was grounded through the neutral conductor.
-KB
Switch Junction box has 3 sets of 3 wires. Can't get dimmer to work knockout Electrical 14 01-10-2015 09:08 AM
Adding additional outlet. Pigtail four sets of wires? svanhess Electrical 5 07-12-2009 10:27 PM
Quick Question - Determining Which Wire is Which (both dead wires) Tryvidy Electrical 13 04-23-2009 06:00 PM
Confusing Chandelier Wires Burnsy Electrical 21 02-22-2009 03:29 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
