220 Volt For Welded - Electrical - DIY Chatroom Home Improvement Forum
Old 06-13-2009, 03:38 PM   #1
220 volt for welded
i'm going to be buying a welder soon and i need to run a 220 volt out let off my main panel (in the garage) out let will be below the main panel.
i under stand 220 wirering some what my question my main panel only hase one space left can i use a Tandem Breaker breaker in this spot for 220.
the breaker looks like this
can it be done? i think so... fill in the gray area for me
tcgreaux is offline   Reply With Quote
Old 06-13-2009, 03:54 PM   #2
300zx's Avatar
Post
You have to look at the specs of panel to see if allowed.Should say on there somewhere.
300zx is offline   Reply With Quote
Old 06-13-2009, 03:57 PM   #3
were would i find that and what would they say
Old 06-13-2009, 03:59 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
That is a twin/tandem/skinny breaker, not a two-pole breaker. That breaker will NOT give you 240v. It will give you two 120v circuits.
You need TWO spaces for a 240v circuit.
IF, and only if, your panel will accept twin breakers you can use one to free up a space in your panel by consolidating two 120v circuits to one space. Even this has risks so be sure you know what you are doing first.
Old 06-13-2009, 04:01 PM   #5
Also, what size circuit do you need? "220" means nothing without more info.
The circuit you need will be 240v at a certain amperage. The amperage is the size of the circuit.
Old 06-13-2009, 04:10 PM   #6
230v @23 amps the welder requires
Old 06-13-2009, 04:13 PM   #7
300zx's Avatar
Post
op said he has 1 space left emty.With that twin that will free up another space with the one he has alredy so he will have room for 2 pole breaker
Old 06-13-2009, 04:16 PM   #8
300zx's Avatar
Post
Sould show list of breakers you can use on door of panel (bad pic)
Old 06-13-2009, 04:16 PM   #9
No it can not be done. A double breaker only connects to one leg of the service a 220 break connects to both legs.
hayewe farm is offline   Reply With Quote
Old 06-13-2009, 04:18 PM   #10
what does the two pole do that makes it 240volts that cant be acomplished with he tandem (just want ot under stand) and my box almost has all tandem breakers except for two Arc-Fault Circuit Interrupters . and 4 240v double pole
Old 06-13-2009, 04:21 PM   #11
Every other slot is on a separate leg a 240 volt break takes up 2 slots so it is connected to both legs rather than one.
Old 06-13-2009, 04:21 PM   #12
ahh ok so eachs tab going down the box is ever other leg as in
(leg A-leg B-leg A-leg B)
i think im geting how it works
Old 06-13-2009, 04:22 PM   #13
so i would most likly have to run a sub panel?
Old 06-13-2009, 04:24 PM   #14
You might use the double to replace a two 120 volt breakers thus freeing up another slot and install a double breaker.
Old 06-13-2009, 04:27 PM   #15
all of the 120 are doubles not including 2 Arc-Fault Circuit Interrupters 1 for the dish washer 1 for the disposal
220 volt circuit GFCI Captflx Electrical 16 09-29-2011 06:53 AM
How to power a 120/240 volt 3 phase oven in a building with 120/240 volt single phase wantsomegetsome Electrical 9 05-04-2009 10:49 AM
What switch to install between panel and 220 volt heater Rogers Guitar Electrical 4 01-21-2009 06:08 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Different styles of 220 volt recepticles? MrLinux Electrical 8 01-24-2008 06:47 PM
