220 Volt, 30 Amp Extension Cord - Electrical - DIY Chatroom Home Improvement Forum
Old 11-04-2016, 11:58 AM   #1
Rewards Points: 6
220 volt, 30 amp extension cord
Plan on relocating clothes dryer to top of clothes washer. Unfortunately the dryer electrical cord is 24 inch. too short to reach the existing wall outlet. I can either add a new wall outlet where it is needed ( this would require running a wire back some 50 ft. to the main electrical panel,) use the existing wall outlet as a 'J' box and add a new outlet close by or use a suitable extension cord. Note that the existing box cannot be moved.
Is it permissible to use an 'approved'? extension cord for this purpose?
Thank-you.
brooklin is offline   Reply With Quote
Old 11-04-2016, 12:39 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 30,208
Re: 220 volt, 30 amp extension cord
Extension cords are for temp use.
Change the dryer cord. Walmart website shows 4 and 6 foot versions.
Old 11-04-2016, 05:48 PM   #3
Rewards Points: 18
Or use the existing as a junctionbox and run a new piece of 10/3 to a new outlet.
Sent from my LG-D415 using Tapatalk
jeffmattero76 is offline   Reply With Quote
Old 11-04-2016, 10:48 PM   #4
Rewards Points: 80
Joed's solution would be the easiest and cleanest.
Cheers!
supers05 is offline   Reply With Quote
Old 11-04-2016, 11:05 PM   #5
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 528
You're in luck... the NEC restricts that new appliance wire to six feet.... but the internet still sells longer lengths.
MTN REMODEL LLC is offline   Reply With Quote
Old 11-04-2016, 11:23 PM   #6
Usually Confused
lenaitch's Avatar
Rewards Points: 764
I didn't think the NEC ruled on appliances and other peripherals - I thought that was up to UL (CEC and CSA in Canada). By putting a longer cord on it, I suppose the dryer would loose its UL 'certification' and probably negate any warranty, but as long as it's done with the properly sized cable, secure attachment to the appliance, etc. it shouldn't be a problem. I've done it with a couple of my floor tools.
lenaitch is offline   Reply With Quote
Old 11-04-2016, 11:45 PM   #7
Rewards Points: 80
If the cord was a listed replacement cord for that application, probably not. "the original got damaged."
Home owners can get away with murder around here....
Cheers!
Old 11-05-2016, 12:23 AM   #8
Rewards Points: 528
Good point... maybe... I do know you can't buy them at the local vendors... really did not know wheather NEC or UL was at play....
(I'm a GC.... an electrical supply informed me,,,)
Old 11-05-2016, 12:10 PM   #9
Rewards Points: 6
Thanks for all comments. Will change dryer cord with a longer one, 6ft, and I wil then know I have done it correctly and safely...Thanks again.
Running and extension cord to the garage from the basement TESLATESLA Electrical 9 09-23-2015 12:58 PM
extension cord wiring streetneons Electrical 3 04-08-2014 10:39 PM
Extension Cord for Geneartor Question Santiago927 Electrical 3 12-30-2012 03:30 PM
Extension cord to romex kiknit Electrical 5 12-28-2012 05:29 PM
Air Compressor stopped working, extension cord was used. dawho1 Tools 3 10-07-2008 06:14 AM
