20A Line, 15A Receptacle - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-31-2010, 03:23 PM   #16
What happens when you just plug a light into the oulet? does the breaker trip? If it still trips wouldn't that mean it's clearly a mis wire or open somewhere in the circut?
justlosther is offline   Reply With Quote
Old 05-31-2010, 07:10 PM   #17
dSilanskas's Avatar
It's totally legal and fine to put a 15 amp on a 20 amp circuit. Sounds like you have something touching in the outlet box. I bet it's a metal box correct? Remove the outlet and tape the screws on the outlet just make sure you don't have anything touching. Before you screw the outlet back into the box turn the breaker back on to make sure it doesn't spark. You should be fine
dSilanskas is offline   Reply With Quote
Old 05-31-2010, 08:48 PM   #18
It is important to clarify that a single 15A receptacle can only be used on a 20A circuit if it is not the only receptacle on the circuit.
Previous posts are saying the same thing, in that:
A simplex 15a outlet can't be installed on a 20a circuit under NEC code
A 15a DUPLEX can
[I know Scuba means it can't be installed by itself ]
To clarify, you can use 15 amp simplex receptacles on a 20 amp circuit. [...correct...]
It's totally legal and fine to put a 15 amp on a 20 amp circuit. [...correct, as long as there is more than one...]
Willis
williswires is offline   Reply With Quote
Old 05-31-2010, 08:54 PM   #19
dSilanskas's Avatar
A 15a DUPLEX can
Your correct I didn't realize it was a single outlet
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 10:21 AM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 02:56 PM
Add natural gas line Tukeeman Plumbing 11 12-01-2008 07:53 AM
electric line and gas line couch potatoe Electrical 17 09-30-2008 10:43 PM
Condensate Line schott HVAC 17 06-02-2008 03:16 PM
