2002 Pontiac Grand Prix Ignition Issue - Electrical - DIY Chatroom Home Improvement Forum
Old 08-18-2010, 11:39 PM   #1
2002 Pontiac Grand Prix ignition issue
Hey, I've been having an issue with my car for awhile now. Everytime I try to shut my car off it wont shut completely off. For some reason it'll go half way and lock my key to where I cant move it any further. I thought it was just me at first... but then I realized I have to slam my drive shaft into park, and try to shut it off. If that doesnt do the trick then I have to restart my car once again put it in reverse.. then drive,... then slam it into park... anyone have an idea what I should do? its really irritating.
woodjen is offline   Reply With Quote
Old 08-19-2010, 05:46 AM   #2
47_47's Avatar
Rewards Points: 320
There is a Brake, Transmission, Steering Interlock (BTSI) solenoid mounted on the shifter housing. This system does a couple of things. It requires that the brake pedal be depressed before you can shift the car from park into gear. This solenoid also prevents the steering wheel from locking with the car in gear. If the steering wheel cannot go to a lock position, you cannot remove your key. You will need to remove the console and check the linkage. You will probably find it gummed up with a spilled drink.
47_47 is offline   Reply With Quote
The Following User Says Thank You to 47_47 For This Useful Post:
woodjen (08-19-2010)
2002 pontiac gp black3333 Automotive Repairs 3 10-17-2009 10:06 PM
2002 Pontiac Grand Prix Electrical Problem bipper Automotive Repairs 5 07-06-2009 11:06 AM
2002 Pontiac Grand Prix c.sherry Automotive Repairs 1 06-13-2009 07:15 PM
This may help someone with carrier ignition problems AweMan HVAC 15 02-09-2009 01:20 PM
2002 pontiac grand prix gt electrical stevieb Automotive Repairs 2 11-01-2008 07:32 PM
