200 Pool Pump - Electrical - DIY Chatroom Home Improvement Forum
Old 06-06-2009, 06:30 PM   #1
Question
200 pool pump
I have switch at pool pump location, can I install 110v outlet off 220v switch?
rickywb
rickywb is offline   Reply With Quote
Old 06-06-2009, 06:33 PM   #2
dSilanskas's Avatar
Not you need a neutral at the switch and with it being 220 volts you don't have that.
dSilanskas is offline   Reply With Quote
Old 06-06-2009, 06:36 PM   #3
I have black (hot)-white (hot) and insulated green.
Old 06-06-2009, 06:39 PM   #4
300zx's Avatar
Post
Still need a neutral.
300zx is offline   Reply With Quote
Old 06-06-2009, 06:41 PM   #5
Rewards Points: 2,350
It's not a good idea to go screwing around with pool pump wiring. Someone could be killed.
Old 06-06-2009, 06:42 PM   #6
ok no more room in panel, can i run just nuetral wire from panel?
Old 06-06-2009, 07:09 PM   #7
No. Find another circuit or make room in the panel. Don't touch the pool circuit.
Old 06-06-2009, 07:12 PM   #8
They make tandem breakers to replace single breaker with 2 mini breakers. These can ONLY be used for 120v circuits
Old 06-06-2009, 08:18 PM   #9
dSilanskas's Avatar
And that is only if his panel will accept a split mini breaker
Old 06-07-2009, 08:48 PM   #10
OK, Found out Main Panel has one 20amp breaker on right side (black wire)and one 15amp THQL GFCI on left side (white wire), that is supply for 220v to pool pump, is thhis a correct setup or was this done by an amatuer?
Old 06-07-2009, 08:54 PM   #11
" Euro " electrician
frenchelectrican's Avatar
IMO it done by amatuer and it is NOT a legit set up like that you need to change to correct two pole breaker.
The reason why what if one of the conductor shorted out one breaker will trip and the other one may stay on or tripped and also if you want to kill the power to that circuit you have to spend extra time to find two breakers like that if you only turn off one and the other one still enerized ya got distator waiting for ya.
Now you understand why you need a true two pole breaker for this useage.
Merci,Marc
Old 06-07-2009, 08:59 PM   #12
Yes, should this be gfci double pole, 20amp?
Old 06-07-2009, 09:07 PM   #13
Yes if cord et plug attached but hardwired pump useally no it don't need GFCI unless the local codes say something diffrent.
Merci,Marc
Old 06-07-2009, 09:26 PM   #14
Pump is hard wired to on/off switch at filter site.
Thanks for info
New pool pump trips breaker?! New home owner needs advice. KenR7A Electrical 22 01-05-2011 09:42 AM
pool timer/ pool pump hook-up bubbahines Electrical 4 05-29-2009 05:03 PM
connecting pool pump and pool sanitizer Skippy2 Electrical 5 08-17-2008 07:48 PM
Pool Pump Wiring mpdive Electrical 17 06-15-2008 07:30 PM
swimming pool pump wire steel Electrical 5 04-06-2008 08:35 PM
