200 Amp Sec. Svc. Design Overhead/Underground - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 08-19-2014, 09:13 AM   #31
DIYer/PoleMonkey
clw1963's Avatar
Rewards Points: 262
So how will you approach using the bridge conduit? What's your transition? Pull what you need through it to the new panel (short run). Then reel it out to existing panel? What if you nick the insulation jacket installing it? You have burrowing critters nearby? Both spell trouble. Not sure what's allowed, but there is "DB" (direct buried) conduit out there. Thinner than sch 40. I'd explore that option. Maybe someone else will chime in.
clw1963 is offline   Reply With Quote
Old 08-19-2014, 09:18 AM   #32
DIYer/PoleMonkey
clw1963's Avatar
Rewards Points: 262
Originally Posted by brric View Post
You may be able to do it for less but the installation will still be inferior.
Primary closer to service point is best case. But not every best case is practicable. I'm not surprised by the dollar amounts from PG&E and if true, I would choose to use that $$$$$ for the house I'm building.
Old 08-20-2014, 07:11 AM   #33
Rewards Points: 3,396
Not sure whether one 500 MCM conductor has more cross sectional area than two OOOO conductors but if your calculator gives you 3% or less voltage drop (200 amps, 1130 ft. round trip) then the cable you chose will be fine.
Stick to your lawn watering schedule until it really pours. Otherwise the storm might miss and the part that gets watered last (3 days away?) will dry up.
AllanJ is online now   Reply With Quote
Tags
500 feet , 600 feet , overhead , service wire gauge , underground supply
How to transfer a design onto wood? r0ckstarr Carpentry 7 01-23-2014 04:16 PM
Film / Photo Studio Interior Design BryanRoberts Interior Decorating 5 11-30-2011 05:31 PM
How To Check A Steel Carport Design abrogard Building & Construction 8 10-05-2010 03:59 AM
General HVAC Design Issue Robert Green HVAC 4 05-29-2010 11:02 AM
