200 Amp Panel With A 100 Amp Service - Electrical - DIY Chatroom Home Improvement Forum
Old 09-13-2010, 08:50 PM   #1
200 amp panel with a 100 amp service
A brand new manufacture home (800 Sq Ft) came with a 200 amp panel with the whole house wire and using 6 spaces. What would be the best way to run service. I was thinking a meter to a 100 amp disconect to the 200 panel inside home.
vince1016 is offline   Reply With Quote
Old 09-13-2010, 09:06 PM   #2
Where are you located ?
Old 09-13-2010, 09:09 PM   #3
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
What do you mean a 'brand new manufactured home came" ?
Did UPS deliver it or what???
Have you met with the power company and local electrical code department for the city or county to determine their requirements?
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 09-13-2010, 09:10 PM   #4
Electrical Contractor
kbsparky's Avatar
As long as the calculated connected loads do not exceed 100 Amps, connecting a 100 Amp feeder to a 200 Amp panel is acceptable.
Many mobile homes with gas range, heat, etc. can be connected with a 100 Amp feeder, even if the load center is rated for 200 Amps.
You will need a 100 Amp breaker in the outside disconnect box, however.
-KB
200 amp panel w/100 amp service PirateKatz Electrical 8 12-26-2009 03:42 PM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
Upgrade Service Panel - Do I need a new meter? El Kati Electrical 6 08-11-2008 07:35 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
200 amp panel with a 100 amp service? alexz Electrical 10 07-29-2007 10:00 PM
