20 Receptacle On 30 Amp Breaker - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree3Likes
Old 03-03-2019, 07:28 PM   #16
Rewards Points: 320
Re: 20 receptacle On 30 amp breaker
If the dryer is gas, one 20 amp, 120 volt circuit on a GFCI is all you need for both the washer and dryer. Years ago, two circuits would have been needed but with today's energy efficient appliance, one 20 amp circuit you all you need.
The OP has stated that the dryer is electric, not gas.
Let it Snow is offline   Reply With Quote
Old 03-03-2019, 07:31 PM   #17
Rewards Points: 320
Originally Posted by Jim Port View Post
Even the cable used was wrong. The bare ground looks to being used as a neutral. Not sure how a cord was connected to the dryer.
Depending on how old the installation is, years ago, 10/2 would have been code compliant and used a 30 amp, 3 wire receptacle. Neutral and ground were bonded inside the electric dryer.
Old 03-03-2019, 07:33 PM   #18
Rewards Points: 320
The photo is post #12 shows a gas dryer.
Old 03-03-2019, 07:39 PM   #19
Super Moderator
joed's Avatar
Rewards Points: 22,634
That dryer has a regular 15 amp plug. It has to be gas.
Old 03-03-2019, 07:42 PM   #20
Rewards Points: 26
oh man i have a lot to learn lol....yes the dryer is gas..i thought it only ran on gas and did not need to be plugged in so its clear now why its working off one cable wire meaning i will have to install another receptacle to my breaker problem solved thank you for the replies!
detroit48210 is offline   Reply With Quote
Old 03-03-2019, 07:46 PM   #21
Super Moderator
joed's Avatar
No need for another receptacle. All you need to do is change the breaker to 20 amp and all will be fine.
Old 03-03-2019, 07:49 PM   #22
Rewards Points: 320
Gas Dryer, Change the breaker to 20 amp and install a GFCI receptacle. Now you're code compliant.
Old 03-03-2019, 08:00 PM   #23
Licensed electrician
Rewards Points: 3,592
Not with NM cable. The bare ground cannot be used as a neutral. Type SE cable was allowed.
brric and jhil like this.
Old 03-03-2019, 08:00 PM   #24
hkstroud's Avatar
Rewards Points: 5,542
i installed a 20amp duplex outlet on a single wire in my basement with 10-2 wire connected to a 30 amp breaker
It is not clear what you are doing. Are you working on your house or your mothers house? Or are they one and the same.
You still cannot install a 20 amp duplex outlet on a 30 amp circuit. If your mother's washer circuit, change the breaker to 20 amps and replace the outlet if you wish, not required.
Jim, its a gas dryer.
Harold,
The Left Handed Widget Maker
hkstroud is offline   Reply With Quote
Old 03-03-2019, 08:05 PM   #25
Electrical Contractor
jbfan's Avatar
Rewards Points: 540
Originally Posted by dmxtothemax View Post
QUOTE - [ I would like to know if this is a safety hazard and dangerous.]
Yes it is a safety hazard,
You have a 30A breaker a 30A cable but only a 20A outlet.
Therefore the outlet is NOT protected from over current.
Seperate the outlets,
Put two single 20A outlets side by side,
One for the dryer and one for the washer.
These could run off the 30A line.
Maybe down under this si allowed, but not in the NEC, General use receptacles can not be installed on a breaker larger than 20 amp.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 03-03-2019, 08:15 PM   #26
hkstroud's Avatar
Now I'm really confused. If you last photo was looking down behind the dryer which it appears to be
I don't see any gas piping but I do see what looks to be 10/3 cable that looks to be hardwired to the dryer. The black cord plugged into the lower half of the receptacle appears to curve back toward the washer.
So what is it, a gas dryer or an electric dryer?
Harold,
Old 03-03-2019, 08:53 PM   #27
Rewards Points: 396
That's a copper gas line in the picture
jhil is offline   Reply With Quote
Old 03-03-2019, 09:44 PM   #28
Rewards Points: 26
sorry yes that is the gas line so indeed it was a gas operated dryer
Old 03-03-2019, 09:55 PM   #29
hkstroud's Avatar
Sorry didn't mean to add to the confusion.
Getting old is hell.
Harold,
Old 03-04-2019, 11:26 PM   #30
Rewards Points: 364
Most electric dryers can be modified to run on 120 volts. It will take forever to dry anything that way, though. But I've seen it done lots of times in apartments where a 240V circuit was not available.
fa_f3_20 is offline   Reply With Quote
how do I wire 120V, 30A breaker and receptacle? anuvanoob Electrical 5 02-14-2018 07:04 AM
Main AC breaker tripping when auxiliary heat comes on Orion625 HVAC 7 01-07-2018 02:42 PM
One Breaker Trips Another Breaker outburst Electrical 29 05-25-2016 03:30 PM
Added new breaker, no garage lights now. lum1nes Electrical 8 08-04-2012 07:50 PM
breaker keeps tripping RMCarner Electrical 29 07-22-2012 09:53 AM
