2 Prong Receptacle To 3 Prong Receptacle - Electrical - DIY Chatroom Home Improvement Forum
Old 12-21-2009, 09:39 PM   #1
2 prong receptacle to 3 prong receptacle
I did check and saw that this has been covered before, let me tell you what I found and see if I need a cfgi outlet. I pulled the cover on the old 2 prong and found two sets of bundled wires each bundle had three wire running in it a black and white wire that run to the receptacle and a bare cooper wire that was screwed into the box, one at the top and one at the bottom.
NP
Nektopols is offline   Reply With Quote
Old 12-21-2009, 09:55 PM   #2
Where is the outlet located ?
As long as you have a ground you can upgrade to a 3 prong
---as long as the ground goes back to the panel eventually
If you need a GFCI depends upon location of outlet
Old 12-21-2009, 10:00 PM   #3
It's in a bedroom and I'm not sure where the bare cooper wire runs to, looks like the original from when the house was built (1957) and the box it sits in is metal.
NP
Old 12-21-2009, 10:13 PM   #4
If you have a test light or meter, connect between the black and the bare wire. If it reads 120 volts or the light works it is most likely a bonded ground. You should the connect a pig tail to the outlet and the bare wires. To bring to current code you should install an AFI receptacle in bedroom.
hayewe farm is offline   Reply With Quote
Old 12-21-2009, 10:15 PM   #5
Will a digital ohm meter work for the test?
NP
Old 12-21-2009, 10:18 PM   #6
If you mean a digital multi meter set on ac volts, yes.
Old 12-21-2009, 10:30 PM   #7
An AFCI receptacle ?
I've yet to see one, & would imagine the price would be very high
Old 12-21-2009, 11:03 PM   #8
Dave you are right, I should have said AFI protection.
Wire recessed light from a 3 prong receptacle? prc114 Electrical 9 12-22-2009 09:29 AM
Wiring A Ceiling Fan, Receptacle, and Outside Light merlin6984 Electrical 9 03-26-2009 09:52 PM
Receptacle Rating question Ultrarunner2017 Electrical 5 12-18-2008 05:36 PM
Please help, changing dryer cord from 3 prong to 4 prong oldpirate Electrical 8 08-10-2008 04:42 PM
Split Receptacle on 3-Way Circuit NPS Electrical 6 11-03-2005 09:28 AM
