2 Prong GROUNDED Outlets - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree18Likes
Old 06-19-2019, 02:21 PM   #16
A "Handy Husband"
rjniles's Avatar
Rewards Points: 604
Re: 2 prong GROUNDED outlets
Originally Posted by Oso954 View Post
They also folded back over the outer sheath of the cable and made multiple wraps that would lay under the Romex clamp. This was called a Boston back wrap.
There were a lot of methods used before the NEC specified the grounding method.
How did a left coaster learn about Boston back wrap? I thought that was totally and east coat thing.
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 06-19-2019, 05:04 PM   #17
Rewards Points: 5,662
Originally Posted by Anti-wingnut View Post
Call an electrician. You canít even fathom that two is not three.
That's funny, since in your previous post you seem to be confused about what 2 poles means!
jeffnc is offline   Reply With Quote
Old 06-19-2019, 05:07 PM   #18
Originally Posted by rjniles View Post
Plug one of these in.
Then test with this to see if the box is grounded
Well, that doesn't even have a chance of working if the screw for the cover plate isn't screwed through the ground hole.
However, I'd take that tester into the kitchen and see if those outlets are grounded first. My guess is someone installed a GFCI outlet in the kitchen, but it isn't actually grounded. Or, maybe someone has grounded that circuit.
Old 06-19-2019, 05:41 PM   #19
Rewards Points: 1,290
A two prong recepticle is two pole. The standard three prong recepticle is two pole with ground.
Thinking you’re probably the confused one.
Anti-wingnut is offline   Reply With Quote
Old 06-19-2019, 05:49 PM   #20
A "Handy Husband"
rjniles's Avatar
Rewards Points: 604
Duh!
Sent from my RCT6213W22 using Tapatalk
Old 06-19-2019, 05:52 PM   #21
Contractor/Engineer
Rewards Points: 1,106
By law, the landlord has to provide a safe environment for you.
Any device that you have with a three prong plug most likely REQUIRES that device to be plugged into a grounded outlet in order for that device to function properly and safely for you.
A two prong outlet is NOT grounded.
You should let your landlord know that you cannot use your microwave, your computer and any other 3-prong device without voiding that device's warranty requiring a grounded plug. And as a result, the apartment/condo is not habitable under the terms of the rental/lease agreement.
Domo is offline   Reply With Quote
Old 06-20-2019, 09:56 AM   #22
Habitability probably refers to heat, light, sewer and water. So your argument could fall on deaf ear with the owner and court.
jbfan and Oso954 like this.
Old 06-20-2019, 10:03 AM   #23
Oso954's Avatar
Rewards Points: 1,778
Like
That not habitable argument is a huge stretch. I think you would lose.
Oso954 is offline   Reply With Quote
Old 06-20-2019, 11:13 AM   #24
Rewards Points: 3,182
An ungrounded outlet is not unsafe. If you intend to utilize devices which require 3-prong grounded outlets, it's up to you to rent an apartment that can accommodate them.
jbfan likes this.
LawnGuyLandSparky is online now   Reply With Quote
Old 07-04-2019, 01:18 AM   #25
Contractor/Engineer
Admittedly, you do make a good point - "let the buyer beware."
