2 Half Hot Outlets, 2 Sources, 1 Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 11-03-2011, 06:57 AM   #1
2 half hot outlets, 2 sources, 1 switch
I know I need to break the tab, but do I have the wiring correct in this, to scale, artist rendered, image?
830ttime is offline   Reply With Quote
Old 11-03-2011, 07:10 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 6,432
What do you mean 2 sources?
Do you have power in and power out to the next device?
If that is the case, you have it wired correctly.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 11-03-2011, 07:47 AM   #3
I also wonder about the two supplies. If these two supplies are on two separate circuits, and if these are on different legs of the split-phase house supply, this looks to me as if this is going to trip some breakers (or worse).
oberkc is offline   Reply With Quote
Old 11-03-2011, 08:03 AM   #4
Super Moderator
joed's Avatar
Rewards Points: 30,866
What I see there is two half switched receptacles with unswitched power feeding off to anther device provided you breaker the HOT tab only.
Old 11-03-2011, 08:50 AM   #5
The source for each outlet (each on opposite walls) is coming straight from from the breaker box feeding no other devices. So the wires marked with an S go directly to the service box.
Old 11-03-2011, 08:57 AM   #6
jbfan's Avatar
In that case you have a problem!
One of the feeds has to go, or you need to add another switch.
Old 11-03-2011, 09:08 AM   #7
Could I completely separate the two plug-ins on one of the receptacles and utilize the power from the other outlet to power the top plug of the other.
So on my image, the bottom plug in on the left outlet would be powered by the source and the top getting power from the outlet on the right?
This sound really confusing to me and I know what I want to say. I will create another drawing and attach.
Old 11-03-2011, 12:50 PM   #8
OK....How about this....
Old 11-03-2011, 12:51 PM   #9
Super Moderator
joed's Avatar
That works because now you have two separate switches controlling the receptacles. The double pole switch will need the tab broken so the two hots don't interconnect.
Old 11-03-2011, 12:53 PM   #10
Gotcha. Thanks a million.
Old 11-03-2011, 12:55 PM   #11
Just so I am 100% clear, I need to break the hot tab on BOTH Receptacles and the Switch, yes?
Old 11-03-2011, 01:53 PM   #12
jbfan's Avatar
Correct.
Old 11-03-2011, 04:06 PM   #13
mem
Rewards Points: 156
From what I've been learning here--doesn't he need to get a neutral (or two) into that switch box to meet code?
mem is offline   Reply With Quote
Old 11-03-2011, 04:15 PM   #14
Sparky
Rewards Points: 510
if he's under 2011 NEC yes he does if 2008 he doesnt
Techy is offline   Reply With Quote
Old 11-03-2011, 06:10 PM   #15
Super Moderator
joed's Avatar
You are correct about the white. His drawing is bit deceiving. I looked quickly and thought he was using a three wire cable but appears you are correct he is pig tailing a red to the white.
How to make a full switch recepticle half switched and half constant power? johncdbass Electrical 8 11-15-2010 12:19 PM
3 Way Switch Issue (after replacement) mpukit Electrical 11 09-20-2010 03:12 PM
Wiring Outlets Then Switch Then Lights heydj Electrical 9 05-07-2009 08:09 PM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
GFCI switch to control outside outlets billgeo Electrical 14 09-08-2008 11:09 PM
