2-2-2-4 URD Cable - Electrical - DIY Chatroom Home Improvement Forum
Old 10-05-2014, 07:09 AM   #1
Rewards Points: 264
2-2-2-4 URD cable
Can I use 2-2-2-4 Aluminum URD to connect a 100amp subpanel box? I was going to use the 4 gauge aluminum wire as the ground (it's an attached garage - just the way everything is laid out, I think it's going to be easier to run it underground than through finished drywall)
tibberous is offline   Reply With Quote
Old 10-05-2014, 07:24 AM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Just a side note, the NEC does not recognize URD as a wiring method, you would have to make sure it has a USE-2 type insulation or XHHW.
URD without another listing cannot be used for any NEC application.
USE without another listing can be used for NEC applications outside only due to no flame rating.
Duel listed USE/RHW can be used for NEC applications inside and outside.
Old 10-05-2014, 03:04 PM   #3
Rewards Points: 248
Type USE (underground service entrance) #2 is only good for 90 amps and would require at least a #6 equipment grounding conductor.
Jake. is offline   Reply With Quote
A shovel accidentally hit an outside buried coax cable miamicuse Electrical 24 05-03-2014 02:30 PM
Locating Service Cable from Meter to Panel the_titan Electrical 5 02-28-2014 01:22 PM
Evaluating a kinked cable dave11 Electrical 5 05-09-2010 10:20 AM
Underground service entrance cable requirements. kgt55 Electrical 9 06-22-2009 06:55 AM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 02:54 PM
