DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Electrical (https://www.diychatroom.com/f18/)
-   -   16 gauge wire to an 8 gauge wire (https://www.diychatroom.com/f18/16-gauge-wire-8-gauge-wire-87974/)
jbvw 11-28-2010 05:02 PM
If you have an extension cord with two 16 gauge twisted strand wires and you twist the ends together to make one wire, is it now equivalent to an 8 gauge wire?
McSteve 11-28-2010 05:06 PM
No.
oleguy74 11-28-2010 05:44 PM
what ever you are trying to do ...DON'T....
AllanJ 11-28-2010 07:00 PM
Two 16 gauge wires twisted together at both ends are roughly equivalent to one 12 gauge wire.
This may not be used for household wiring, either permanent or portable, but could be used for portable low voltage or loudspeaker wiring.
A 16 gauge wire emerging from a device such as a light fixture may be wire nutted to an 8 gauge feed wire but there is little usefulness* for this. The circuit feeding the light fixture or receptacle may not be breakered at more than 20 amps for which 12 gauge wires are sufficient.
* One use would be for a very long run, say hundreds of feet.
Speedy Petey 11-28-2010 10:00 PM
I agree, what ever it is you are trying to do, STOP!
The fact that you are asking this is downright scary.
frenchelectrican 11-28-2010 11:21 PM
Whatever you do that part.,,, Ce n'est pas sūr { it is not safe }
Why you want to do soemthing with This ?? there is proper conductor sized items you can do in safe way.
Merci.
Marc
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
