15a Vs 20a Outlets?? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-07-2010, 07:21 AM   #16
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
Originally Posted by mopowers View Post
Thanks for the help guys. I'll go ahead and just install the 15a receps since I know I'll never use a tool that will require a 20amp outlet. I will also install a 15 amp gfci as the first recep in the chain. Thanks again.
I would still get spec-grade devices. Do not use cheap $.49 receptacles in a garage. You WILL be replacing them in short order.
I use only spec-grade in all locations now.
Old 03-07-2010, 10:01 AM   #17
Rewards Points: 252
What are 'spec-grade' receptacles?
mopowers is offline   Reply With Quote
Old 03-07-2010, 10:27 AM   #18
Licensed electrician
Rewards Points: 3,654
Spec grade are a more heavy duty type of device. Normally the materials used are tougher or a higher quality. The wires secure using clamps instead of just screws or the back stabs. They also cost more.
Old 03-07-2010, 11:58 AM   #19
Just call me Andrew
Rewards Points: 1,032
This alone makes it worth it. Those clamps are SO much easier and more likely to hold for a long time.
Andrew
secutanudu is offline   Reply With Quote
Old 03-07-2010, 01:20 PM   #20
I prefer the ones without the clamps. I like regular screws.
Spec-Grade also have MUCH better plug retention. Meaning plugs will not fall out after a few years of typical use.
Old 03-07-2010, 02:05 PM   #21
Rewards Points: 252
Thanks guys. I actually just got back from the store. I ended up picking up 20a outlets and a 20a gfci outlet. The price difference was negligible.
This thread got me thinking though. Is it against NEC to use a 20a receptacle on a 15a circuit? I would think not, but it's probably not a good practice.
Old 03-07-2010, 03:10 PM   #22
You can use a 15a (20a pass thru) on a 20a circuit
You can't use a 20a outlet on a 15a circuit
An item that requires a 20a circuit & has the 20a plug requires a 20a circuit
Allowing a 20a outlet on a 15a circuit would defeat that "feature"
Old 03-07-2010, 08:15 PM   #23
Rewards Points: 252
Thanks! I just had an extra 20a outlet. And since I'm adding another outlet in another room, I thought I could go ahead and use it even though the circuit is a 15 amp circuit. I guess I can't though. Looks like another trip to the home improvement store is in order.
Thanks again.
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 12:29 PM
Replacing kitch outlets to GFCI jhubert Electrical 7 11-16-2009 07:23 PM
Power leading to outlets but no power ? s_anthony Electrical 22 01-05-2009 01:08 PM
outlets work, but barely (?) joeyboy Electrical 7 08-27-2008 08:37 AM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
