150am Service To 200amp Service In The Same Can - Electrical - DIY Chatroom Home Improvement Forum
Old 07-03-2010, 03:33 PM   #1
150am service to 200amp service in the same can
my 150 amp service breaker keeps tripping out, i was wondering if my present box will except the 200 amp beaker will the new breaker still trip out. do i have to upgrade the wire in the box. the meter resides in a can of its own and goes in to the main box where the 150 amp breaker is , also the rest of the breakers. this is all on the out side of the house. any help from any one would really be appreciated . can i do this my self? what should the breaker cost approximately. thanks. steve
bandito2 is offline   Reply With Quote
Old 07-03-2010, 04:25 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
a panel is rated for a specific current rating. That means the breaker as well as the bus. You cannot change a breaker in a panel that is less than 200 amp to a 200 amp breaker and have a 200 amp rated panel.
Old 07-04-2010, 06:33 AM   #3
Rewards Points: 1,192
Sounds like a weak main breaker. 150 amps is a lotzawatts!
bobelectric is offline   Reply With Quote
Old 07-04-2010, 08:17 AM   #4
I=E/R
a7ecorsair's Avatar
In addition to the other replies, has anything changed in your electrical arrangement? Do you think your electrical load is close to 150 amps?
No, you cannot change the Main Breaker by yourself - you will need to have the power company pull your meter or you will consume the 150 amps
a7ecorsair is offline   Reply With Quote
cost to change 100amp service to 200amp DIYGST Electrical 2 01-02-2010 09:06 AM
Is it okay to run 4-0 cable 440ft with 200amp service panel jr67z Electrical 3 10-08-2009 08:49 PM
100 to 200amp service in Brookhaven, NY tomshulski Electrical 6 10-01-2009 03:19 PM
150amp to 200amp service upgrade... theatretch85 Electrical 30 07-06-2009 05:02 PM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 10:31 AM
