150 AMP 872 SF House - Electrical - DIY Chatroom Home Improvement Forum
Old 05-05-2010, 02:24 PM   #1
150 AMP 872 SF house
I am buying a home in Asheville, NC and the inspection report says "breaker is double tapped and overfused in main panel". I am going to add central a/c to the house. It currently has a w/d, dishwasher, hot water heater (gas), baseboard heat (elec), fridge, range. I don't want a fire hazzard for an electical panel, so what are my options for making this right? Any idea of the cost?
libertybungalow is offline   Reply With Quote
Old 05-05-2010, 02:39 PM   #2
Licensed electrician
Rewards Points: 3,662
What is the Hi calling overfused? Do they mean the wire is larger than it needs to be? This is not an issue to have a wire larger than needed. However, if the HI actually means underfused, ie the wire is too small for the breaker, this can be an issue and a fire hazard. There are times when the wire is allowed to have a larger breaker than normal like for a motor load.
Some breakers are listed for use with 2 conductors. What is the brand of panel? What is the breaker controlling that has the double tap?
You may just need to install a breaker to correct this issue.
libertybungalow (05-06-2010)
Old 05-05-2010, 02:51 PM   #3
Good questions that I have no answers to! I'll see if the HIspc will tell me more about it. The panel is Cutler Hammer, Squre D according to the HI report.
Thanks.
Old 05-05-2010, 03:35 PM   #4
The panel is a Cutler-Hammer, yet the report says Square D?
Old 05-05-2010, 04:02 PM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 974
The only person that can tell you if it is safe or unsafe the way it is wired, is an electrician.
I just finished a HI report on a large house, and half the issues he wrote up, were in fact non issues, or not code problems.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
The Following User Says Thank You to jbfan For This Useful Post:
Old 05-06-2010, 08:32 AM   #6
Ok, thanks. I have scheudled an electrician to see what (if anything) needs to be done. It sounded "serious" on the report, but I'm finding out that a lot of the items are more for me to just know about and fix when I can. I appreciate the feedback.
My house's previous owner - DIY horror stories Leah Frances General DIY Discussions 153 01-21-2016 07:18 PM
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
New house drywall DISASTER pharm07 Off Topic 13 03-25-2011 02:24 PM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 10:09 PM
Moving a House 70 miles- Practical? GOTHICrevivalRULES Building & Construction 19 11-27-2008 08:58 PM
