15 Amp Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 08-21-2010, 12:47 PM   #1
Tud
15 amp circuit
All of a sudden my 15 amp breaker keeps popping as soon as it's reset. I tired switching the wire to another 15 amp just to see if it was the breaker but it popped instantly. I have lived in this house for 3 years and never had one breaker pop.
Tud is offline   Reply With Quote
Old 08-21-2010, 12:48 PM   #2
Sounds like a short in the wiring
Any renovations, shelves/pictures put up recently ?
Old 08-21-2010, 12:54 PM   #3
" Euro " electrician
frenchelectrican's Avatar
What this circuit is feed to?
The reason why there are few possiblty it may cause the breaker to trip very fast before you keep resetting it will destory the cable so with that circuit that affected unplug every thing off 100% first then try to reset if that still trip then you have to investage if something short out like in attic some critter will chew on the cable.
Otherwise did you put up a picture hanger or drive a nail into something ??
Merci.
Marc
Old 08-21-2010, 02:09 PM   #4
Rewards Points: 1,005
as mentioned. it's an electrical connection "short" from the hot wire (blk) to either neutral (wht) ground (bare or grn) or other grounded conductor. this causes excessive current causing the breaker to trip. the breaker is doing exactly what it is supposed to do - protect the wire from overheating/melting insulation/fire trucks. even if the cb resets at this point, i would not trust this circuit until the culprit is found and repaired. you can physically trace the romex (14/2 ?) as best you can, look for lights or receptacles that don't work. open up the boxes (***). your looking for signs of a short - blackened wires, loose wires, bad connections.
***don't do this if you are not comfortable around electricity. get help if needed.
TimPa is offline   Reply With Quote
Old 08-21-2010, 07:09 PM   #5
Super Moderator
joed's Avatar
Rewards Points: 23,990
Open every box on the circuit and inspect it. You may find a loose connection that has melted a wire nut and is now shorting to the box.
Need a wiring diagram Mooreski Electrical 47 02-01-2015 03:07 PM
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 17 06-11-2011 06:09 AM
Changing a 3 way circuit...using recessed lighting box as a junction box? Oxymoron Electrical 1 12-07-2009 06:46 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 07:59 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 08:09 PM
