15 Or 20 Amp? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-18-2014, 07:40 PM   #1
Rewards Points: 43
15 or 20 amp?
My daughter wants an outlet in her basement for a small deep freezer. They have room in their Breaker Box, some I'm going to put it on it's own dedicated circuit.
Was just thinking a 15 amp breaker with 12/2 with ground and a 15 amp receptacle, as this is how my own deep freezer is setup and never had any issues. Although I don't use that outlet for anything else, where she is saying she might use it from time to time for her vacuum too. And now question if I should go with a 20 amp breaker 12/2 with ground and 20 amp receptacle? Thanks
John28 is offline   Reply With Quote
Old 08-18-2014, 07:58 PM   #2
Licensed electrician
Rewards Points: 3,840
Either should be fine. You will have more flexibility with the 20 amp circuit. If you are installing the #12 you might as well install the 20 amp breaker for the same price and 1/3 more capacity.
If the area is unfinished basement or in a garage you will need GFI protection.
Old 08-18-2014, 07:58 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by John28
My daughter wants an outlet in her basement for a small deep freezer. They have room in their Breaker Box, some I'm going to put it on it's own dedicated circuit. Was just thinking a 15 amp breaker with 12/2 with ground and a 15 amp receptacle, as this is how my own deep freezer is setup and never had any issues. Although I don't use that outlet for anything else, where she is saying she might use it from time to time for her vacuum too. And now question if I should go with a 20 amp breaker 12/2 with ground and 20 amp receptacle? Thanks
12/2, 20 amp circuit breaker, 15amp gfci. Done deal.
The Following User Says Thank You to stickboy1375 For This Useful Post:
Stubbie (08-18-2014)
Old 08-18-2014, 08:05 PM   #4
Rewards Points: 1,832
Id just put a 20amp breaker in. Going one step above ie larger wire for a case like this isn't worth it.
Jump-start is offline   Reply With Quote
Old 08-18-2014, 08:34 PM   #5
Super Moderator
joed's Avatar
Rewards Points: 31,940
If you are running 12/2 anyway use a 20 amp breaker.
Old 08-18-2014, 08:38 PM   #6
Rewards Points: 43
Thanks, I have enough 12/2 laying around so just figured I'd use it, rather than buying 14/2 for a 15 amp circuit.
Old 08-18-2014, 10:59 PM   #7
Welcome
15 or 20amp breaker is fine, but if you have #12, go with a 20 since the added capacity may be worth it.
