136v At Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 01-09-2010, 12:49 PM   #1
136v at breaker
Hi Folks, I have a quick question, I was at a friends house he had a few outlets in the basement not working. Found out the problem was in the wiring and solve the problem. While I was trouble shooting I check the voltage at the breaker to make sure it was working and it read 136v I then checked the voltage at every breaker and they were all reading 136v the question is, is this normal? I have never had a reading of over 125v at a breaker before. He has a Federal-Pacific panel(which I heard many bad things about) don't know how old it is but it looks fairly new(10-15yrs) and a 150amp service. Thanks. Ron
runronno is offline   Reply With Quote
Old 01-09-2010, 01:56 PM   #2
Master Electrician
richgriffith's Avatar
did you check the voltage at the main? if so was it still 136V on each leg to ground.
richgriffith is offline   Reply With Quote
Old 01-09-2010, 02:09 PM   #3
Electrical Contractor
kbsparky's Avatar
You could have one or more of the following problems:
  1. Bad tester
  2. Bad neutral
  3. Bad poco transformer
-KB
Old 01-09-2010, 08:25 PM   #4
I should have, but I didn't, thought about it after I left. was too busy with the other problem. will check it next time I'm there. If it is 136 or 120 what's your suggestion?
Also will check volt meter at home, make sure it's working.
Did some research on Federal Pacific I guesstemated wrong on the age of panel, It has to be from the 80's
Old 01-09-2010, 09:37 PM   #5
Unhappy
They (FPE products) were taken off the market in the (very) early '80s. Some FPE panels and breakers look amazingly like new. Wish they were as good as they appear to be. Especially those that are switched Horizontally (R-L/ L-R) in larger panels.
spark plug is offline   Reply With Quote
Old 01-10-2010, 03:31 AM   #6
Master Electrician
JohnJ0906's Avatar
Replace the battery in your tester. When mine is going dead, it gives some high readings like that.
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Old 01-10-2010, 09:05 AM   #7
Super Moderator
joed's Avatar
Rewards Points: 24,030
Measure the 240 volt supply as well. If it is high then you should call the POCO. Based on your readings it should read somewhere around 270 volts. It is their problem.
Old 01-10-2010, 11:45 AM   #8
Thumbs up
In my (not so old) Analog Multimeter, no internal (Battery or other) power is used to measure volts. Most likely, it is a Power Company problem.! (No matter what) Don't Drink and Drive, ever!!!
Old 01-10-2010, 01:32 PM   #9
Master Electrician
if your still getting 136v per leg to ground at the main the problem is most likely on the power companies end. i suggest then to contact them to come out to check there transformer & connections.
Good luck hope this works. keep us informed on your progress. P.S yeah and make sure your batterys. are good in your tester before you test. i had the same thing happen to me as john said above. you still need a good battery. to get your digital reading.
Old 01-10-2010, 01:56 PM   #10
Well son of a b**** you learn something every day. checked my voltage today with meter got 134v reading... changed the battery, 118v at the same outlet. That's why I like to ask questions. Thanks to all. Ron
20 amp GFCI breaker pops when pool pump is turned on. jagrunner Electrical 11 03-19-2010 04:31 PM
Breaker problem jdhar Electrical 11 06-10-2009 01:18 AM
Sq D Trillaint Breaker problem jmreynol Electrical 3 04-28-2009 07:06 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
