12v To 120v - Electrical - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By FrodoOne
Old 03-23-2020, 10:24 PM   #1
Rewards Points: 2
Lightbulb
12v to 120v
Hi: I have an older desk lamp that has a cord with a transformer, stepping it down to 12volts. I want to swap out the tiny bi-pin bulb that getS SUPER hot with an LED version. All I can find are 120v versions that fit this particular style. Can I simply cut off the transformer and rewire the cord? Thank you!
PRossing is offline   Reply With Quote
Old 03-23-2020, 11:58 PM   #2
Rewards Points: 1,518
Re: 12v to 120v
Are they GU10 bulbs?
seharper is offline   Reply With Quote
Old 03-24-2020, 12:04 AM   #3
Rewards Points: 58
The no pin base is voltage specific so a bi pin 120 volt bulb will not fit your lamp. The spacing between the pins will be different.
Wiredindallas is offline   Reply With Quote
Old 03-24-2020, 12:44 AM   #4
Rewards Points: 3,012
Re: 12v to 120v
It is likely to be quite unsafe to apply 120 V to a device designed and wired for 12 V.
Also, if there is any metal in its construction, that metal should be Grounded BUT, in your 12 V device, it will NOT be Grounded.
Buy a nice new LED desk lamp.
(For example https://www.staples.com/Turcom-Relax...roduct_2614801, which is dimable, the colour temperature can be changed and it has a USB charging port.)
seharper likes this.
FrodoOne is offline   Reply With Quote
Old 03-24-2020, 06:33 AM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 884
Re: 12v to 120v
You have a 12v bi-pin halogen lamp. 12v bi-pin LEDs are available.
Sent from my RCT6A03W13E using Tapatalk
My electrical answers are based on 2017 NEC, you may have local amendments.
Tags
120v , 12v , transformer
