DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Electrical (https://www.diychatroom.com/f18/)
-   -   120V on Disconnected White Wire, is that normal? (https://www.diychatroom.com/f18/120v-disconnected-white-wire-normal-660999/)
CubsBears2017 06-13-2019 07:59 PM
I was working on some electrical, and as I was taking stuff apart and then going to put it back together, I noticed the white wire has 120V, but isn't that suppose to have 0 (or near 0) all the time?
Currently its not connected to anything is that why its at 120V? Should I
connect it to the other 2 white wires, which are currently capped together?
TIA
chandler48 06-13-2019 08:20 PM
Re: 120V on Disconnected White Wire, is that normal?
How did you test this wire for 120 volts? Where does it come from and where does it go and what does it control?
CubsBears2017 06-13-2019 08:23 PM
With a multimeter.
It goes to behind the wall and presumably to another outlet which stopped working after I unhooked everything. Not sure where its coming from, other than the wall.
Is that normal though for it to have 120v?
chandler48 06-13-2019 08:28 PM
Not unless it is part of a switch loop. With the multimeter you would touch the white wire and ground. Is that what you did? Where is the associated black wire in the group? Can you post pictures of this junction box? Is or was there a receptacle in the box?
CubsBears2017 06-13-2019 08:42 PM
Ah, it very well could be part of a switch loop.
With the multimeter I touched the red to the white wire and the black to the metal junk box. I'm not sure which black wire is part of it, could it be a blue or red wire?
Here are some photos (in the photo with the single box, its the white wire on the bottom left), and this branches another outlet and set of switches which are not pictured.
https://i.postimg.cc/s2BYLxxY/IMG-6844.jpg
https://i.postimg.cc/VvwX5FRg/IMG-6845.jpg
LawnGuyLandSparky 06-13-2019 09:08 PM
You can and will read voltage on a disconnected white wire if there's a load looking for a neutral.
CubsBears2017 06-13-2019 09:14 PM
So it should typically be connected with other neutral (white) wires?
Jim Port 06-13-2019 09:23 PM
The circuit will not be completed without the neutral connection.
The disconnected neutral carries the same voltage as the hot.
LawnGuyLandSparky 06-13-2019 11:42 PM
I can't say I have no idea what you're doing. "I'm working on some electrical, I was taking stuff apart and going to put them back together" isn't enough information to answer why the white wire has voltage, or if it's a neutral, or if it should be tied in with other neutrals.
CubsBears2017 06-14-2019 07:41 AM
Is there any easy way to fix this without tearing the whole house apart?
CodeMatters 06-14-2019 07:50 AM
Hmmm...cubs and bears...??? Chicago area? Right?
Those look like conduits, not cables.
White is used for other purposes than neutral when cable is used. White
should be used for neutral only when in conduit.
EDIT: Therefore, see post 6.
LawnGuyLandSparky 06-14-2019 12:30 PM
How many wires are in the left conduit, and what colors? How many wires are in the right conduit, and what colors? What is this box for and where is it? What was in this box before it was taken apart?
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
