120/208 120/240 High Leg Delta Panel - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-07-2010, 10:14 PM   #16
Rewards Points: 2,800
The 2 gauge copper wire in free air (strung from the utility pole) can carry 150 amps. In a cable or conduit coming down to your panel 2 gauge is for 100 amps. Splice on a 1/0 or fatter copper up at the entrance head to bring down 150 amps.
The unequal sized feeders were probably intended to go first to a disconnect switch and then branch to a 120/240 volt single phase subpanel and to a 3 phase subpanel.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
Main panel or sub panel? tbeaulieu Electrical 5 04-07-2010 11:58 AM
Placement of Electrical Panel theatretch85 Electrical 4 01-05-2010 12:05 AM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 05:54 AM
