12 AWG Circuit, 14 AWG Cable For The Last Load -- A Switched Light - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Like Tree13Likes
Old 04-18-2019, 09:10 AM   #31
Rewards Points: 5,556
Re: 12 AWG circuit, 14 AWG cable for the last load -- a switched light
Originally Posted by Tom153 View Post
Also, I wonder if there is a different code requirement for plastic interior piping. I don't have plastic, so I don't look for it.
I'm pretty sure there is not. There was once an idiotic discussion on this forum a couple years ago, where some foolish people were arguing that water wasn't a safety issue with regard to electricity, because "most" modern plumbing is plastic. One of the underlying ideas in the electrical codes is that things can often change, and the code tries to make things safer by covering whatever might be there. The fact that plastic doesn't conduct electricity really doesn't enter into it. It's even possible that electricity could be conducted through running water down through your plastic pipes to a point where it touches metal and ground.
jeffnc is offline   Reply With Quote
Old 04-19-2019, 09:43 AM   #32
Licensed electrician
Rewards Points: 3,592
Originally Posted by jeffnc View Post
Originally Posted by Oso954 View Post
GFCI protection is required on all kitchen countertop receptacles. The sink doesn’t make a damn bit of difference.
If you think about it, every metallic appliance in your kitchen (large or small) is a pretty good ground (assuming an EGC and 3 prong plug). You get caught between a hot leg and almost any metallic surface in the kitchen, and you are talking about a phase to ground short with you in the center of it.
It certainly does matter. This is why GFCI are required in bathrooms, garages and exterior locations as well - potential wet areas. There are no "metallic appliances" expected to be on your back deck or bathroom, for example. Now it just might be that if there were some strange room in houses that had a lot of "metallic appliances" but no wet area for some reason, that the code would require a GFCI there too, but since there is no such thing, the "raison d'etre" for GFCI is the presence of water. Water is a pretty decent conductor of electricity, and that's the bottom line w.r.t. the code.
The earlier post inferred that GFI protection was only required near a water source in the kitchen. The requirements are for ALL countertop receptacles to be GFI protected. Therefore the statement that the sink doesn't matter.
mpoulton likes this.
Old 04-24-2019, 12:08 PM   #33
Rewards Points: 42
This is my solution to remember that there are multiple circuits in one box:
Nealtw likes this.
StevenS is offline   Reply With Quote
Old 04-24-2019, 01:19 PM   #34
The height of fashion! I'm sure all the women of the house will love that. Wouldn't it make more sense to put that inside the box?
Old 04-24-2019, 03:41 PM   #35
Super Moderator
joed's Avatar
Rewards Points: 22,714
I write the breaker #s on the inside of the cover plates. Not many home owners like them on the outside.
Wiring an added recessed light circuit with 1 dimmer and one switch Username10 Electrical 27 03-12-2019 12:10 AM
Routing 2 electrical 14/2 cables in a bookshelf Kcrew98 Electrical 2 03-11-2019 11:16 PM
Connecting a cable light system to a track light system megabyzus Electrical 42 11-17-2013 07:06 PM
Adding additional light fixture to switched circuit woodardhsd Electrical 5 07-07-2011 09:06 PM
new light to existing switched light sirsparksalot Electrical 4 04-22-2011 03:23 PM
