12/3 Wire Feed Outlets? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-06-2010, 06:48 PM   #1
walt1122
Rewards Points: 446
12/3 wire feed outlets?
Hi All, Putting outlets in the basement. Small room under the porch is "L" shaped maybe 35 X 25 by 7.5 feet wide. Superior Walls so one side is solid concrete while the other is set up for electric wire and sheetrock. I had all this 12/3 wire around so I thought I would run all the outlets down the easy side and not cut thru the conctete to put in a few outlets. I have no heating set up so I want to use electric space heaters. So between the heaters, a TV, some sundry items, treadmill and who knows what I wanted to be sure I had enought electric so started to use the 12/3 thinking I could alternate outlets one black hot, then one red hot etc. Can I share the white neutral? Is this legit. Plan on putting on 20A double pole 240V.
thanks
Walt
walt1122 is offline   Reply With Quote
Old 12-06-2010, 06:52 PM   #2
Rewards Points: 1,192
Too much splicing for me.Spend $96 on a roll of 12-2 nm.
bobelectric is offline   Reply With Quote
The Following User Says Thank You to bobelectric For This Useful Post:
walt1122 (12-06-2010)
Old 12-06-2010, 07:01 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 23,990
You can do as you want. The neutrals need to be pigtailed to the receptacles so that removing a receptacle does not break the neutral .
You you mention some things that need addressing.
1. Treadmills usually need a 20 amp circuit just for themselves.
2. Small heaters might be OK on the circuit but I would not put them on the same circuit as your electronics.
3. As living space all these receptacles need to be AFCI.
The Following User Says Thank You to joed For This Useful Post:
Old 12-06-2010, 07:15 PM   #4
thanks
Walt
You don't really say how many outlet you want but I don't think I would put heaters and electronics together. Heaters can draw a alot. I think I would just get some 12-2 but if you want to use you 12-3 I would run one leg to the treadmill and the other leg to your electronics and then just buy enough 12-2 to run a third for your heat.
The other thing you could do, even though I don't think I would. You could run the heat off the treadmill circuit when the treadmill is not in use. Basically you would only be able to use one at a time. When your run, unplug the heater and when the heater is on, don't run the treadmill. The other thing is that you could just wait until you get bored with the treadmill and sell it like %95 of people do, then you can use the outlet for the heater exclusively.
sbfan2000 is offline   Reply With Quote
Old 12-07-2010, 12:18 PM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 968
You will also need receptacles along the concrete wall to meet code.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 12-07-2010, 02:28 PM   #6
Rewards Points: 459
Not an electrician, but this brings to mind: "Wouldn't you potentially be returning up to 40 amps through the single 12ga neutral wire?"
Nick DIY is offline   Reply With Quote
Old 12-07-2010, 02:44 PM   #7
...No...
walt1122 (12-09-2010)
Old 12-07-2010, 04:52 PM   #8
walt1122
Rewards Points: 446
Hi all, thanks Nick DIY that is what I was concerned about and prompted me to ask the question in the first place.
So that issue and the other one thinking I could get away with not having to put in the outlets on the concrete side.
Jbfan is it code even if the the room is only 7 1/2 feet wide.? If so then both of these issues will be a problem. Guess I will have rethink this and might just have to buy the 12/2 afterall. Don't feel like having to cut thru 2 inches of concrete, having to run emt or put up a false wall taking away more of the 7 1/2 feet of width.
and the treadmill thing that is the wife's idea. Bought it two years ago and all it is used for is to drape stuff over. If I could I would get rid of it tomorrow but...like I said the wife wants it so it stays. Think she expects me to use it but I just want the man cave so I can hide out and read more DIY Chatroom questions.
thanks again
Walt
Old 12-08-2010, 06:22 PM   #9
Electrical Supplier
Rewards Points: 150
First, AFCIs are NOT required for rework....yet.....unless your local code adopted that.
Second, yes you have the potential to return 40A on that neutral.
I would wire the heaters separate. Easier to D/C in the off season.
Heaters pull around 1500w or about 13 amps for space heaters at least.....
"Do it right the first time and avoid duplication of effort"
Your AHJ/Inspectors ALWAYS have the final say on ANY electrical code issue.
If in doubt, contact a licensed, experienced, reputable electrician to perform the work.
LyonsElecSupply is offline   Reply With Quote
Old 12-08-2010, 06:27 PM   #10
Master Electrician
Rewards Points: 5,082
A properly installed MWBC will NOT have double amperage on the neutral. The most the neutral will carry is 20 amps if there is no current on one of the hots.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
Old 12-08-2010, 06:37 PM   #11
Electrical Supplier
Rewards Points: 150
Forgot about the 180 phase alternation. Forget it, its been a long day.
As long as you use a 2pole breaker it will not be over 20amps.
The Following User Says Thank You to LyonsElecSupply For This Useful Post:
Kitchen GFCI with 12/3 feed zapped Electrical 17 10-23-2010 10:15 AM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 04:02 PM
Replacing kitch outlets to GFCI jhubert Electrical 7 11-16-2009 07:23 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
12/3 Romex to Feed 2 Circuits? DaveHembree Electrical 22 09-28-2007 08:24 AM
