12/2 Without White - Electrical - DIY Chatroom Home Improvement Forum
Old 01-28-2010, 11:37 PM   #1
Question
12/2 without white
I have Romex 12/2 with a ground, black wire and red wire inside the jacket. No white. Is this common? Is the red neutral?
Lunker is offline   Reply With Quote
Old 01-28-2010, 11:43 PM   #2
jlhaslip's Avatar
Rewards Points: 708
that would be for 220 volt. 2 hots and a ground.
I'm not a sparky, but use the red for neutral might work. can't say if it would pass code... I'm a carpenter.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 01-29-2010, 04:20 AM   #3
Was it on a heater circuit?
jerryh3 is offline   Reply With Quote
Old 01-29-2010, 05:29 AM   #4
Too Short? Cut it Again!
Cannot use RED/BLACK/GROUND for regular wiring and expect it to pass a code inspection.
Old 01-29-2010, 05:35 AM   #5
It's Canada.
Old 01-29-2010, 06:03 AM   #6
Originally Posted by jerryh3 View Post
It's Canada.
Change my comment from cannot to should not then.
Old 01-29-2010, 06:17 AM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
WHY?? In Canada this is perfectly legal and complaint.
It may even be code required for heating circuits. Anyone? JoeD?
Old 01-29-2010, 06:41 AM   #8
Rewards Points: 2,800
Yes, that cable is used for switch loops and for 220 volt only circuits.
But what was said so far confuses me: Are you or are you not permitted to remark the red wire with white bands at the ends to use the cable for ordinary 110 volt (hot & neutral) circuits? At least in the U.S. you are not allowed to do that.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 01-29-2010, 09:48 AM   #9
Thanks for the replies.
No, it was not for heaters. It was a run that the previous homeowner made in a partially finished basement. I was told it was planned for a chain of 5 outlets on a 20amp breaker for an entertainment wall that was never finished. Obviously he bought the wrong wire. I was hoping I wouldn't have to replace it, as it's a 50' run from the panel.
Old 01-29-2010, 10:22 AM   #10
Super Moderator
joed's Avatar
Rewards Points: 23,958
Is the outer jacket red? That stuff is made to be used for 240 volt loads. It is called HEATEX cable. I have heard of inspector allowing it if the exposed red wire is covered with a white heat shrink.
http://www.ebhdirect.com/default.asp...10+RED+X150+CU
Old 01-29-2010, 10:50 AM   #11
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 528
I would just use white tape to mark the red wire as white, and you should be fine, I would think...
Painting white martinigirl Painting 3 04-26-2009 06:24 PM
Off White Trim/Base/Crown with White Ceiling/Doors? StyxTx20 Interior Decorating 4 12-15-2008 07:54 AM
12/2 wire vs "heater wire" shtoink Electrical 11 11-23-2008 02:16 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Whatcha thinka NOT painting interior moulding white? Davo Interior Decorating 7 07-07-2007 07:58 PM
