12-2 Wire That Is Actualy 14-2 - Electrical - Page 7 - DIY Chatroom Home Improvement Forum
Old 04-21-2010, 10:37 AM   #91
Originally Posted by JakAHearts View Post
Thanks HooKoo. We were typing at the same time. You put that a lot easier than I was trying to convey. So one 12-2 circuit for all three outlets in the bathroom and keep the 14 for the lights and fan.
Can one spot house both the GFI and switch for the lighting even though they are wired seperately?
Also, am I better off starting a new thread and letting this old thing die or...?
Shane
Two circuits can share the same box; however, the grounds of both circuits must be tied together in the box.
HooKooDooKu is offline   Reply With Quote
Old 04-21-2010, 10:42 AM   #92
According to code, nothing wrong with that, but in most bathrooms I've seen, the switches are by the door at a normal switch height, while the GFI receptical is mounted a little lower near the sink basin (if the sink basin has a wall beside it, the outlet is usually several inches above the counter top and behind the mid-point of the sink basin).
Old 04-21-2010, 10:53 AM   #93
Knows everything but that
Rewards Points: 150
I have a seperate area for the vanity/sink area. It is pretty far from the entrance so Ill have two seperate light switches. One for the sink/vanity and one for the toilet/shower. Youve been very helpful, thank you!
Shane
JakAHearts is offline   Reply With Quote
Old 04-21-2010, 11:36 AM   #94
Just call me Andrew
Rewards Points: 1,032
You can have two circuits in the same box, but mark the wires as such, and do not mix up the neutrals.
Also remember that only your first outlet needs to be GFCI, if you feed the rest of them from the LOAD side of the outlet. Everything connected to the load side is also protected. Once you wire it, you can verify that it is all protected by pressing the TEST button on the GFCI - just make sure the other outlets are also dead.
A moderator may separate this discussion into a new thread, since it's gone a little off-topic
Andrew
secutanudu is offline   Reply With Quote
Old 04-21-2010, 12:36 PM   #95
Rewards Points: 596
Originally Posted by InPhase277 View Post
Or, for more traditional units, 0.000000000000000002175 light-years.
Pshht. I did the Lowe's run in less than 12 parsecs.
operagost is offline   Reply With Quote
Old 04-22-2010, 12:06 PM   #96
In which Star Wars episode was that?
Old 04-22-2010, 01:07 PM   #97
Star Wars episode 14 - "A New Dope"
New Stove, old wires - 2 wire vs 3 wire DIYGST Electrical 22 03-02-2009 04:13 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 01:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 09:00 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
