12-2 Underground Feeder In Conduit - Electrical - DIY Chatroom Home Improvement Forum
Old 05-21-2017, 09:21 PM   #1
Rewards Points: 143
12-2 underground feeder in conduit
Hello,
Need to run (2) lines of 12-2 with ground underground feeder for irrigation pumps. One line will be 240v and one will be 120v.
Need to go under a walkway. Can I place both of these lines in 3/4" conduit under the walkway only? 1" conduit? If neither, what size conduit do I need while going under the walkway?
Thanks in advance for your assistance.
7474 is offline   Reply With Quote
Old 05-21-2017, 09:45 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 802
Re: 12-2 underground feeder in conduit
Are you using the conduit just for the walkway, or the whole distance?
Under the walkway, is fine.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 05-21-2017, 09:55 PM   #3
Rewards Points: 143
Thanks for the reply.
It will just be in conduit under the walkway. Wanted to make sure there wasn't any issue with placing it in the 1" conduit (overheat, etc)?
Thanks again for taking the time to reply.
Possible underground PVC conduit leak miamicuse Electrical 10 09-20-2015 11:24 AM
underground electical lines BlueBSH Electrical 11 02-10-2012 03:52 AM
Pulling large gauge wires through conduit bodies and conduit around garage door. rrolleston Electrical 65 02-07-2012 03:11 PM
code requirement on conduit going through roof that main feeder wires come through rebelbull Electrical 22 01-28-2012 10:38 AM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 06:49 PM
