12 And 14 On Same Yoke - Electrical - DIY Chatroom Home Improvement Forum
Old 06-25-2014, 09:55 PM   #1
Rewards Points: 455
12 and 14 on same yoke
Yo, can I run a 12-2 and 14-2 to a tandem switch that will be switching two different items on the same yoke ? anyone see any nec problems with this?
Cletis is offline   Reply With Quote
Old 06-26-2014, 04:38 AM   #2
Rewards Points: 1,192
I don't see a problem.
And I don't see why you were banned from that professional site, eithter.
bobelectric is offline   Reply With Quote
The Following User Says Thank You to bobelectric For This Useful Post:
gregzoll (06-26-2014)
Old 06-26-2014, 06:14 AM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 6,762
Dennis says he wasn't banned.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 06-26-2014, 07:00 AM   #4
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,112
I believe under the 2014 NEC the switch has to be listed as a multi-circuit.
All responses based on the 2014 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 06-26-2014, 07:35 AM   #5
Rewards Points: 455
if i'm not banned then why does it say registered user and my pic is gone on my post then
Old 06-26-2014, 08:39 AM   #6
jbfan's Avatar
Good question.
Old 06-26-2014, 10:54 AM   #7
Rewards Points: 3,256
Type in "Registered Member" in your custom user title and remove your pic...Bam!!
zappa is offline   Reply With Quote
Old 06-26-2014, 02:41 PM   #8
Rewards Points: 1,832
He was banned from ET.
This link, 4th post:
http://www.tradeworksforum.com/t441p...et-reject#6407
Jump-start is offline   Reply With Quote
Old 06-26-2014, 06:57 PM   #9
Maybe he never hit OK.
Maybe that image is from one of the 5 other lifetime bans.
Old 06-26-2014, 07:03 PM   #10
Rewards Points: 455
Please stick to the thread topic or leave my thread !!!
Old 06-26-2014, 07:48 PM   #11
Can't you make it a 2 gang? Over / under switches look amateur.
Old 06-26-2014, 08:58 PM   #12
Rewards Points: 455
Can't, it's wedged in between studs in that area. No choice
Old 06-28-2014, 06:07 AM   #13
Rewards Points: 3,404
Almost all duplex receptacles and duplex (tandem) switches and combination switch/receptacle units have tabs you can bend and break off allowing use on two different circuits. For receptacles you need to break off the tabs on both the hot (gold) and neutral (silver) sides for multi-circuit usage, since the neutrals of different circuits may not be interconnected up in the house.
Stick to your lawn watering schedule until it really pours. Otherwise the storm might miss and the part that gets watered last (3 days away?) will dry up.
AllanJ is online now   Reply With Quote
Yoke Replacement tk3000 Plumbing 11 05-25-2014 12:55 AM
Yoke & Meter Spot tk3000 Plumbing 7 05-03-2014 10:50 PM
How do I connect a ground wire to the water pipe? Quackerjack Electrical 18 12-08-2012 11:14 AM
yoke screws that come with Leviton outlets getting stripped amakarevic Electrical 12 09-16-2012 10:38 AM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 06:34 PM
