110v To 220v Problem.... - Electrical - DIY Chatroom Home Improvement Forum
Old 10-30-2010, 12:36 PM   #1
110v to 220v problem....
I have a friend that took two 110v outlets and wired them together to make one 220v outlet would that work or would it fry the appliance over time? It was a washer and dryer, the dryer being the appliance that needed 220v. He is trying to sell me the washer and dryer and I'm afraid that he has damaged it over time.
hockeyguyinoc is offline   Reply With Quote
Old 10-30-2010, 01:06 PM   #2
Mad Scientist
If the dryer still works now, it's probably fine. The guy's probably going to burn his house down with that attitude towards wiring, but that's a separate issue.
McSteve is offline   Reply With Quote
Old 10-30-2010, 10:20 PM   #3
Rewards Points: 2,800
That method of connecting up the washer/dryer won't hurt the washer/dryer.
But that method is electrically unsafe.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 10-30-2010, 11:52 PM   #4
Just call me Andrew
Rewards Points: 1,032
If he's a good friend, tell him how unsafe that is and to hire an electrician.
Andrew
secutanudu is offline   Reply With Quote
Old 10-31-2010, 01:57 AM   #5
" Euro " electrician
frenchelectrican's Avatar
The way the word describing I have a feeling this is in non owned place so if that the case they have to get ahold of landlord to deal with it.
But if this person is legit owner of that home the simplest way is to run a new circuit for dryer but if you are not really understand the electrical system it will be wiser to get a hold of electrician to deal with it.
Merci.
Marc
Old 10-31-2010, 06:22 AM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
Your friend is yet another in a long line of McGrubers. He has NO clue what he is doing and is going to get someone killed eventually.
What he did way VERY wrong and unsafe. You should tell him this.
I would not buy anything from him, nor would I spend too much time in his house.
The Following User Says Thank You to Speedy Petey For This Useful Post:
frenchelectrican (10-31-2010)
Old 10-31-2010, 08:55 AM   #7
57_Hemi's Avatar
HAHAHA
so true
57_Hemi is offline   Reply With Quote
Old 10-31-2010, 09:53 AM   #8
It is very unsafe. Hire a real electrician.
JohnJak is offline   Reply With Quote
75 year chimney leak problem mstanleyg Building & Construction 10 03-30-2010 12:38 PM
Convert 220V to 110V RCCarpetCare Electrical 2 03-15-2010 08:52 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
110v vs. 220v gunboatbay Electrical 17 05-15-2008 08:09 AM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
