110 From 220 - Electrical - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By BigJim
Old 11-03-2019, 01:21 PM   #1
Rewards Points: 16
110 from 220
Hi, I'm trying to add a 110V receptacle to an outside wall in order to power a soft water unit. The only electrical that's close to my softener is a 220V pump that is switched. There are 2 110V hot wires connected to the switch which is then connected to the pump through the switch but there is no neutral. Is there a way that I can make a 110V receptacle by pulling power from the one of the hot wires of the switch if there is no neutral? If so, how would I configure the wiring? I assume, if there was a neutral, I would simply take one of the hots and the neutral to create a 110V receptacle. Thanks in advance.
Gregavi is offline   Reply With Quote
Old 11-03-2019, 01:30 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 1,275
Re: 110 from 220
I am not an electrician, you will have to wait for one to answer most of your questions but, running a 110 line from one leg of the 220 breaker is not a good idea, if that 110 shorts out, it will not kick the 220 breaker. I may be wrong so a real electrician will have to answer this also.
Colbyt likes this.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 11-03-2019, 01:30 PM   #3
Rewards Points: 8,633
Re: 110 from 220
Even if you had a neutral there is no safe legal way to do what you want to do.
Colbyt
Retired drapery and home furnishings installer.
Fact: World-wide 96.5% of Covid-19 victims fully recover
Colbyt is online now   Reply With Quote
Old 11-03-2019, 01:40 PM   #4
Property Mgt/Maint
Rewards Points: 8,202
Re: 110 from 220
No. You will need to pull power elsewhere.
[political signature removed]
Yodaman is offline   Reply With Quote
Old 11-03-2019, 02:02 PM   #5
Rewards Points: 16
Re: 110 from 220
Thanks to all of you. I will take your advice and pull a new line from the main panel.
Also, shouldn't there be a neutral for the 220 pump and switch? It was done many years ago by who knows who..
Old 11-03-2019, 02:22 PM   #6
Naildriver
chandler48's Avatar
Rewards Points: 3,428
Re: 110 from 220
Unless the 240 volt application has a need, such as a timer, clock, or other lower voltage application built in, the 240 volt set up needs no neutral.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 11-03-2019, 06:07 PM   #7
Rewards Points: 58
Another option is to get a transformer fed from the 240 volts.
Wiredindallas is offline   Reply With Quote
