100 Amp Subpanel ?'s - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 04-15-2014, 08:58 AM   #31
Rewards Points: 2,005
There is very little cost difference in a loadcenter with several additional spaces .
God bless
Wyr
WyrTwister is offline   Reply With Quote
Old 04-15-2014, 11:33 AM   #32
I just installed a regular 100amp load center like this one here from Square D with 20 circuit slots. A few more if you use those little skinny twin breakers.
I invited my inspector for a pre-visit walk-thru after my framing was up, told him my intentions, etc. He recommended #2-3 SER running from the main panel to my sub. That was fun to install! I also invited him back for a in-progress visit just to be sure everything I was doing was up to code. I had decided to put 20-amp service to all outlets and 15-amp service only to ceiling lightning. I also wanted to install a lot more duplex and quad boxes throughout the basement, but in particular in my office/media/audio listening room. One split-mini, 3000 watts of electric baseboard heat, small refrig, equipment room, vintage electronics, etc., etc. Hence the requirement for more circuits - zoned to be able to shut-off certain parts of the basement, or sections of rooms. I know it's overkill, but it's what I wanted and I didn't want to experience similar issues I had with my former home/house. Plus, I loathe extension cords! And cost is only a minor factor. I'm sure most electricians would think I'm odd for over 'electrifying' my space, but I'm happy and have done all the wiring myself and will have commercial grade outlets right where I want/need them and at the right height. And hopefully there will be no dimming of house lights when we put up seasonal lights!
Rick
redjr is offline   Reply With Quote
Old 04-15-2014, 12:16 PM   #33
Oso954's Avatar
Rewards Points: 1,852
You are violating code if you put tandem breakers in that panel.
If you buy the CTL tandem breakers (the right ones for a CTL panel) they won't even go in.
Oso954 is offline   Reply With Quote
Old 04-15-2014, 04:05 PM   #34
Well, I don't want to violate code. I wasn't planning on using any tandem breakers, I just thot I remember my inspector saying I could use them. Ah, now that I think about it, he was referring to using tandems in my main service panel because I have to move a couple of circuits to make room for my 60 amp breaker.
Edit: Are some panels designed not to accept tandem breakers to force code compliance when necessary? I was under the mistaken understanding then that all panels have a few slots where tandems can be used. I'm glad I won't need them then and will have plenty of slots, but not many spares.
Old 04-15-2014, 04:58 PM   #35
A "Handy Husband"
rjniles's Avatar
Rewards Points: 888
A panel that accepts tandems will be listed as (for example) "20 slot, 30 circuit"
My electrical answers are based on 2017 NEC, you may have local amendments.
The Following 2 Users Say Thank You to rjniles For This Useful Post:
MTN REMODEL LLC (04-15-2014), redjr (04-16-2014)
Shed subpanel BrandonD Electrical 21 10-14-2012 12:06 PM
Several Questions...leading to Garage Subpanel willstutely Electrical 5 01-03-2012 01:38 PM
Subpanel Right Below Main dcapone Electrical 6 01-02-2012 04:46 PM
Problems with Square D Subpanel bltglt507 Electrical 16 12-04-2009 08:44 PM
A few slightly different questions on subpanel wiring. Chris Dopp Electrical 8 06-26-2009 09:45 PM
