100 Amp Jumper - Electrical - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By Justin_99
Old 04-10-2017, 08:33 AM   #1
Rewards Points: 4
100 Amp jumper
When I had my home built I had the electrician run a 100 amp alum line to the outside of my garage so that We could power a shop at a later time. I know have the shop. Do I need to put the panel on the house or can I do some sort of extension connection I need to go an additional 30' to the shop where there I want a breaker box. Help would be appreciated.
omat13 is offline   Reply With Quote
Old 04-10-2017, 08:51 AM   #2
Rewards Points: 462
Re: 100 Amp jumper
Please explain????
"additional 30' to the shop" Did you build a shop and it is in a separate location from your garage and 30 feet away from the end of that wire?????
"Do I need to put the panel on the house"
Is this where your main electric panel is? Are you considering doing this and not use that 100 amp wire to your garage at all? Is that the question?
Are you going to get an electrical permit?
Bondo and MTN REMODEL LLC like this.
Justin_99 is offline   Reply With Quote
Old 04-10-2017, 09:19 PM   #3
Rewards Points: 4
Re: 100 Amp jumper
Let me explain a little more. I have a 100 amp wire ran to a box which has no posts just protects the wire. I would like to extend this to a shop that I just finished which is about 30 feet away. I would put a 100 amp breaker box in the shop. In my main home breaker box I have a 100 amp breaker that is ran to just outside of the garage. I assume I will need a junction box here then continue the run to the shop. As far as permit it is not needed I am in the country and no city or county code is required. But I want to keep this to code.
Old 04-11-2017, 09:18 AM   #4
Rewards Points: 462
Re: 100 Amp jumper
I would run a new wire from the house to the shop.... But first search for voltage drop calculator (google.com) to be sure you buy a large enough wire based on the total distance and load.
You may want to hire an electrician to do this initial installation and calculation. If the wire is not large enough, you may plug in something like an air compressor and it will just hum. Well worth it to do it right from the get go.
P.S. When you sell a house, they like to see building and electrical permits for additions. Insurance companies like to see permits - inspected and passed for additions as well. Or in other words, I've heard some people have had problems when selling if work was done without having a permit. You area may be lawless and different? But many areas are this way!
Old 04-11-2017, 11:54 AM   #5
J. V.'s Avatar
Rewards Points: 524
Re: 100 Amp jumper
If the electrician ran the correct size wire to the outside of the garage, all you have to do is splice these wires to the new wires you will bury going to the shop.
Of course these splices must be in a suitable enclosure.
Use the search function for this forum using the title "sub Panel".
This is clearly one of the most discussed subjects here.
I would use the cable already installed and size the feeder to it, should it not be 100 amp worthy.
And lets hope he ran 4 wires and not three?
If it worked before you worked on it. You did something wrong.
Old 04-12-2017, 02:12 AM   #6
Red Seal Electrician
Old Brian's Avatar
Rewards Points: 92
Re: 100 Amp jumper
Not sure which country you are in. In Canada the inspection regime for rural areas is either a Provincial inspector, or a Supply Authority inspector. Living out in the country doesn't exempt anyone from an electrical inspection. Perhaps an American electrician can chime in on the U.S. situation.
Cheers,
Brian
Old Brian is offline   Reply With Quote
Re-routing a Bonding Jumper Wire t60 Electrical 13 07-30-2012 03:05 PM
6 AWG bonding jumper through attic (thhn/thwn?) jcrack_corn Electrical 13 03-04-2012 06:55 PM
prv jumper wire 47_47 Electrical 8 10-07-2010 02:44 PM
water meter ground wire jumper not needed? windowguy Electrical 13 07-21-2009 05:37 PM
Converting Main Panel to Sub: How to jumper? HomeOwner42 Electrical 46 02-19-2009 03:28 PM
