10 AWG For 120' Run? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-18-2015, 10:49 PM   #1
Rewards Points: 2
Wink
10 AWG for 120' run?
I am planning on running electrical from my breaker panel at the house to a garage. The total run will be about 120 feet. The garage has a refrigerator and a freezer in it, as well as a few lights.
About 20% of the way down the 120 foot run, I want to put an outlet for outdoor use (lights, maybe an electric smoker in the future, etc.)
The 120 foot run will be in conduit and I plan on using outdoor rated wire. The question is, should I use 10 AWG or is 12 AWG sufficient? If I use 10 AWG, what size breaker should I use?
I was thinking about running the 120 foot run as one run, and then doing a separate run along side it for the outlet about 30 feet down the line. Can I connect them both to the same breaker?
Thanks for your help!
sf23103 is offline   Reply With Quote
Old 08-18-2015, 11:00 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 23,968
You can not install more than a 20 amp breaker on it if you want normal duplex receptacles.
Old 08-18-2015, 11:51 PM   #3
Rewards Points: 2
Got it. Overall is that run length ok with 10AWG and a 20 amp circuit?
Old 08-19-2015, 12:01 AM   #4
Rewards Points: 516
I'm assuming it's a detached building. You'll want a sub panel out there instead of an individual circuit.
Arrow3030 is offline   Reply With Quote
