10-3 Wire To A 3-prong Dryer Outlet - Electrical - DIY Chatroom Home Improvement Forum
Like Tree5Likes
  • 3 Post By rjniles
  • 2 Post By rjniles
Old 04-21-2019, 10:30 AM   #1
Rewards Points: 34
10-3 wire to a 3-prong dryer outlet
Wire: Black, Red, White, bare ground.
Outlet: two straight blades and L-shape
Black to one straight side, Red to the other.
What should I wire to the L-shape, ground or neutral, and what should I do with the spare wire?
Thanks!
paparush is offline   Reply With Quote
Old 04-21-2019, 10:39 AM   #2
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,470
Re: 10-3 wire to a 3-prong dryer outlet
Originally Posted by paparush View Post
What should I wire ....
New dryer? You match up the dryer INTERNALS with what the house provides.
If it's YOUR old house and a NEW dryer...
then upgrade the feed to match up.
TarheelTerp is online now   Reply With Quote
Old 04-21-2019, 10:55 AM   #3
Rewards Points: 50
Is the wire you are referring to the dryer cable, or the cable back to the service panel?
If the wire back to the panel does not have 3 conductors plus a bare ground then it should be upgraded.
daveb1 is offline   Reply With Quote
Old 04-21-2019, 11:02 AM   #4
Rewards Points: 34
Hi Dave,
The wire back to the service panel has 4 wires: Black, Red, White, and bare ground. I'm wondering is it safe to connect this to a dryer outlet that has only 3 connection points and if so, how to wire the outlet?
Old 04-21-2019, 11:05 AM   #5
Rewards Points: 34
Old dryer into an older house that got rewired. I guess they upgraded the wiring to the dryer with newer wire.
If I go to a 4 prong outlet to match the 4-way wiring coming in from the service panel, how do I attach a 4-prong cord to replace the 3-prong cord on the dryer itself?
Old 04-21-2019, 11:22 AM   #6
MarginallyQualified
Ask the Landlord to replace the receptacle with the older 3 wire type.
Or do that yourself and on your own hook.
Old 04-21-2019, 11:24 AM   #7
Rewards Points: 34
I'm the owner.
Old 04-21-2019, 11:28 AM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 206
Install a 4 wire dryer receptacle and a 4 wire dryer cord.
joed, brric and BluegrassGuy like this.
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 04-21-2019, 11:36 AM   #9
Rewards Points: 34
Thanks for the reply. The question then becomes, how do I install a 4 pronged cord onto a dryer that has a 3 pronged cord?
Old 04-21-2019, 11:46 AM   #10
A "Handy Husband"
rjniles's Avatar
Rewards Points: 206
The cord white wire attaches to the neutral of the dryer, the cord green attaches to the frame of the dryer. Remove the strap between the neutral terminal and the frame of the dryer.
joed and daveb1 like this.
Old 04-21-2019, 11:53 AM   #11
Rewards Points: 34
Thanks! Just found YouTube vid showing the same thing.
Tags
10-3 , dryer , outlet , wiring
Dryer outlet. Dryer is 2 straight, 1 L shaped. Outlet is 3 prong straight cam86john Electrical 9 09-08-2017 04:46 PM
Light Switch controlling more outlets as well as high light. Help TheObserver Electrical 1 06-25-2017 02:40 AM
Dryer Wire Split (Ontario Code Question) Electricwire Electrical 11 04-03-2017 07:44 PM
[Help] changing a Maytag dryer from a 4 prong cord to a 3 prong cord noonance Electrical 8 02-26-2013 08:12 PM
3 prong outlet to 2 wire system?? smawgunner Electrical 2 01-24-2011 11:38 AM
