X13 Motor Starts And Stops - HVAC - DIY Chatroom Home Improvement Forum
Old 09-10-2020, 10:30 AM   #1
x13 motor starts and stops
When thermostat calls for AC, the motor starts (x13 motor) and stops every few seconds. The fan does start moving but the system doesn't fully start. The motor makes a slight noise (like something is shorting) then shuts off.
A very quick look online seems to suggested replacing motor unit - but wanted to get additional thoughts before ordering anything. Does that make sense? Should I be looking elsewhere in electrical system or does it sound like bad electronics in motor unit?
justintvd is offline   Reply With Quote
Old 09-10-2020, 10:35 AM   #2
user_12345a's Avatar
Rewards Points: 88
Re: x13 motor starts and stops
make sure it's getting continuous line and control voltage before condemning the motor. do you have a meter?
if it's out of warranty and dead, go for generic replacement to save money.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is online now   Reply With Quote
Old 09-10-2020, 11:25 AM   #3
Thanks, user_12345a! I'll try to do more voltage testing later today. Hopefully I can find indication of what's what as far as wiring.
Definitely out of warranty.
Old 09-10-2020, 12:32 PM   #4
Rewards Points: 4
Thatís pretty common before they go out altogether. Have seen it many times. Although I agree to check voltage first
BayouRunner is offline   Reply With Quote
Old 09-10-2020, 12:53 PM   #5
Thanks, BayouRunner!
Looks like the original x13 is no longer available - if it does come down to it and I need to order replacement does an Evergreen EM make sense?
Old 09-10-2020, 03:13 PM   #6
Rewards Points: 30
Read this:
https://www.diychatroom.com/f17/vari...-motor-117160/
Especially my reference to a much older but fantastic explanation by Bob Reynolds
Your fix could cost you $10 if you're willing to pull motor and examine board.
Happy hunting!
diyorpay is offline   Reply With Quote
Old 09-10-2020, 03:46 PM   #7
Rewards Points: 88
deleted.
Old 09-10-2020, 03:53 PM   #8
Thanks, all! I grabbed a meter and I'm reading 230v into the motor and 27v on control pins 1 & 3 when thermostat is calling for AC. With consistent voltage and fan spinning/shutting off every few seconds does it sound like a motor/controller is likely?
(also... after turning unit off and unplugging connectors from motor to read labels and plugging them back in and turning the unit on - the system did start for 10 or 20 seconds then it turned itself off again)
Old 09-10-2020, 04:47 PM   #9
Rewards Points: 88
sound like bad motor.
Old 09-11-2020, 01:15 PM   #10
Motor runs Genteq Program# 604253-07, motor w/module part number #27W74.
Any clue if a Genteq Evergreen 6205E will work as a drop in replacement?
Tags
hvac , lennox , x13
