X13 ECM Blower Motor Replacement? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 06-13-2020, 12:03 PM   #16
Rewards Points: 30
Re: X13 ECM Blower Motor Replacement?
If you want to take a deep look:
2 pics: Newer version (not one I had years ago for heat) has putty like stuff around problem part (thermistor). Check spelling.
Old one was mine in early 2000's. Part looked about size of quarter.
Burns will often be obvious. This one little part causes complete failure. That's why this component that runs really hot is always being 'upgraded'.
Board alone may be available.
Tiny failed part keeps going up in price but is just a solder replacement.
Here is a primer: see Bob Reynolds input
https://www.diychatroom.com/f17/carr...-problem-9939/
diyorpay is offline   Reply With Quote
Old 06-13-2020, 01:22 PM   #17
user_12345a's Avatar
Rewards Points: 48
Yes, you can check the thermister and see if it's bad.
If there's nothing obviously wrong which can be fixed, buy a replacement evergreen of the right hp. Verify everything including frame size.
If you want, use your meter to verify low and high voltage is at the motor with a call for cooling.
You can wire it the same way - after, the airflow can be determined by putting it in heating mode and calculating it based on temperature rise and heater kw.
You want around 1200 cfm.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is online now   Reply With Quote
Old 06-14-2020, 06:40 AM   #18
Rewards Points: 625
Thanks!
Appreciate the link and pics!
a1481155 is offline   Reply With Quote
Old 06-14-2020, 06:44 AM   #19
Rewards Points: 625
Thanks!
First, I just want to confirm that this the schematic that you wanted to see. If yes, what did it tell you about motor speeds that were looking for?
X13 ECM Blower Motor Replacement?-fb89563f-9c2a-440b-9cd7-77f4472d3bcc_1592135088722.jpg
Old 06-14-2020, 08:58 AM   #20
Rewards Points: 48
it's the correct diagram - showed me how it's wired and that one speed is used for heating/cooling, another for continuous fan.
Old 06-17-2020, 07:58 AM   #21
Rewards Points: 625
Thanks!
With the Evergreen EM and what that schematic showed you, what else would you need to be able to guide me on wiring correctly and selecting/testing speeds?
Old 06-17-2020, 08:42 AM   #22
Rewards Points: 30
From your schematic and a pic:
Blue wire in pic set to 5. Hi Hi For a 3 ton unit
Probably correct. Fan on (only) will be a lower speed.
Old 06-30-2020, 09:30 AM   #23
Rewards Points: 625
Thanks!
I’m still trying to confirm with the seller that this Evergreen EM is compatible with my air handler. (https://www.amazon.com/gp/aw/d/B00STQ3S7O/)
As for wiring, do I put each wire back in the same location on the replacement motor that I remove them from on the current motor?
Old 06-30-2020, 01:23 PM   #24
Rewards Points: 48
i believe the wiring is similar if not the same but always follow manufacturer's instructions.
start with the same speeds - may require adjustment but focus on getting it going for now.
Old 06-30-2020, 04:29 PM   #25
Rewards Points: 30
I agree with 12345.
Give it a shot.
If too high, go down a speed (move blue wire from 5 to 4).
Old 06-30-2020, 07:01 PM   #26
An old Tradesmen
Rewards Points: 54
https://www.supplyhouse.com/MARS-108...RoCM88QAvD_BwE
Old 07-01-2020, 11:40 AM   #27
Rewards Points: 625
The seller of this one says it’s not compatible with my air handler.
I’m still waiting to hear back from seller on this one: https://www.amazon.com/6207E-Genteq-.../dp/B07J1P157J
To me, they seem like the same unit, so I’m not sure what the difference is, but under “Features and Details” they both say “DOES NOT REPLACE EON , 3.0 , 2.3 and 2.5 ECM Motors”. I don’t know if that means 3 ton ECM motors, which mine is.
Old 07-01-2020, 11:49 AM   #28
Rewards Points: 625
Thanks!
I’m a bit confused by the listing saying “1/2 - 1 HP, 115/230V“. Does that mean, this particular unit works for all of those different HPs & Vs or there are other units available in the various HPs & Vs, like 3/4 HP, 230V, which I need?
Old 07-01-2020, 11:51 AM   #29
Rewards Points: 48
The mars azure auto programs itself for the application - it tests how much torque is required to achieve a given rpm and auto sizes.
It's an alternative to the evergreen.
The correct speed tap still has to be selected - cfm can be determined by testing with electric heat, calculating based on temperature difference.
Old 07-01-2020, 12:22 PM   #30
Rewards Points: 625
Thanks!
I called Supply House dot com and they said that one particular unit works for all of those different HPs & Vs, but couldn’t confirm that it’s compatible with my air handler.
