Wrong Run Capacitor? - HVAC - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By raylo32
Old 05-11-2016, 09:44 AM   #1
Rewards Points: 36
Wrong run capacitor?
My question is about my run capacitor for a heat pump unit. The compressor says it requires a "45 mfd 370v" capacitor, but the run capacitor on the unit is 25+5mfd. Is that the wrong capacitor for the unit or is there some other reason the run capacitor is less than what it says on the compressor?
Thank you!
munstie is offline   Reply With Quote
Old 05-11-2016, 09:58 AM   #2
Rewards Points: 907
Re: Wrong run capacitor?
Yes, that's the wrong cap, should match the compressor.
Bitters is offline   Reply With Quote
Old 05-11-2016, 10:04 AM   #3
Rewards Points: 36
Guess that would explain why sometimes it would work fine, and sometimes it wouldn't engage the compressor....
Old 05-11-2016, 11:09 AM   #4
Rewards Points: 907
I'm surprised the 25 mfd would start the compressor.
Old 05-11-2016, 11:32 AM   #5
Rewards Points: 144
Capacitors have a tolerance rating on them .Some are as much as 10% depending on the quality .You should try and match the capacitance as close as possible .The voltage is fine as long as it meets or exceeds the requirement.
mako1 is offline   Reply With Quote
Old 05-11-2016, 12:36 PM   #6
Rewards Points: 36
Every time the ac/heat was off for a while it would be a pain getting it to run again. I'd have to flip breakers numerous times and 'something' would eventually catch and the compressor would work.. it would work fine for weeks/months till either it set for awhile without coming on, or the power would flicker/go off.. then back to flipping breakers. I've told 3 different service men this and they just wanted to add freon, which I did twice.. second time I had them put a sealer in. Guy that came yesterday (guy #3) said may be time for a new one since it's 15yrs old.. said the pressure was low, but hard to say since compressor didn't work.. he checked the capacitance and the capacitor was in limits for what it was labeled, but not that it was the correct capacitor.. so have a new run capacitor coming..
Old 05-11-2016, 01:05 PM   #7
Rewards Points: 907
After the right cap is installed and you are still having the same problem, ask them to install a hard start kit. Might gave you a few more years.
Old 05-11-2016, 01:20 PM   #8
Rewards Points: 36
So you think just putting the right capacitor in won't fixit?
Old 05-11-2016, 03:56 PM   #9
raylo32's Avatar
Rewards Points: 1,288
He is only saying "if" it isn't enough. Try the correct standard cap first, then if that doesn't cut it get a hard start cap kit. Old worn out equipment sometimes will need a little extra kick is all.
Bitters likes this.
Live long and prosper.
raylo32 is online now   Reply With Quote
Old 05-13-2016, 03:36 PM   #10
Rewards Points: 36
Well the new run capacitor didn't do it.. I was watching the electric meter as the compressor was trying to kick in and it would occasionally speed up for a second or two, but never fully engage. Does this mean that either my compressor is shot, or I'm low on freon, or possibly both, other? I could drop more cash and get the hard start kit, but it still may not work. thoughts?
Left feedback to the HVAC repair company that was out three times and didn't notice the wrong capacitor. Supposedly they are going to call me Monday, see what they offer as a remedy.
Old 05-13-2016, 03:47 PM   #11
Rewards Points: 907
Best way to see if the compressor is bad is to OMH it out, Does it trip the breaker?
Old 05-13-2016, 03:56 PM   #12
Rewards Points: 36
Not familiar with how to do that.. did a quick google search and no luck. Have any links or can you explain the process?
Old 05-13-2016, 04:25 PM   #13
Rewards Points: 907
Go to youtube and check out drzarkloff. He has some good vids.
The Following User Says Thank You to Bitters For This Useful Post:
munstie (05-13-2016)
Motors, capacitors and windings KDGrayson HVAC 3 04-10-2015 05:15 AM
start capacitor blown lee12 HVAC 13 09-20-2010 09:01 AM
Need help finding specific capacitor! mark2741 HVAC 21 07-25-2010 09:20 PM
run capacitor blew up caught fire in AC unit. saltshaker30 HVAC 2 07-01-2010 10:08 PM
Condenser motor and Capacitor confusion ryanru HVAC 5 06-26-2010 01:25 PM
