Wine Cooler Compressor Not Starting - HVAC - DIY Chatroom Home Improvement Forum
Old 07-04-2020, 10:20 AM   #1
Rewards Points: 2
Wine Cooler Compressor not starting
Hi, first post on the forums and I really hope to learn alot and provide/get help.
I have a wine fridge that turns on but the compressor does not power on. I just hear clicking every 30 seconds or so.
I have measured the following:
- condenser fan works
- power going to relay good
- relay not broken, measures good resistance. No broken parts.
- compressor pins measure continuity
- overload protector also measured around 0.06ohms.
Is there something else I can check to pin point the issue?
Looking forward to the responses.
Thanks again.
- Damian
dcattena is offline   Reply With Quote
Old 07-04-2020, 10:34 AM   #2
Rewards Points: 894
Re: Wine Cooler Compressor not starting
Easiest thing to try. Replaces the relay and adds a start capacitor for small money. YouTube videos show how easy it is to install.
https://www.amazon.com/Supco-RCO810-.../dp/B00A8O0E5Y
57TinkerMan is offline   Reply With Quote
Old 07-06-2020, 03:19 PM   #3
Rewards Points: 30
Although a mini-fridge question, my response was about solving my wine cooler issue:
https://www.diychatroom.com/f47/mini...t-warm-683909/
diyorpay is offline   Reply With Quote
Old 09-15-2020, 06:13 AM   #4
Rewards Points: 2
If your compressor wine fridge is not cooling, one of the reasons might be a defective thermostat. This component is responsible for the supply of power to the condenser, evaporator fan, and compressor.
Phoenixedward is offline   Reply With Quote
Old 09-15-2020, 06:41 AM   #5
Rewards Points: 308
Hi, that clicking every 30 seconds sure sounds like the relay, I have had the same thing with watercolors and the relay was always the issue, the thermostat is calling or you wouldn’t be getting the clicking.
Geo
Geochurchi is offline   Reply With Quote
