Window AC BTU's Needed? - HVAC - DIY Chatroom Home Improvement Forum
Old 05-09-2020, 02:25 PM   #1
Rewards Points: 40
Window AC BTU's needed?
How many BTU's should a window AC unit be for our living room in a very old house with two open doorways leading to other rooms? It measures 16' X 13' X 7' high. It won't be a closed room since it has open walkthroughs to the dining room and hall. It's on the first floor. The summer heat can be like max 90 or so with high humidity. Thanks a lot!
Spring4ward is offline   Reply With Quote
Old 05-09-2020, 02:29 PM   #2
Rewards Points: 40
Sorry the post got messed up. It is 13 by 16 by 7 ft high. How many btu
Old 05-09-2020, 02:30 PM   #3
Rewards Points: 40
Here’s a pic if it matters
Old 05-09-2020, 03:13 PM   #4
user_12345a's Avatar
Rewards Points: 38
Re: Window AC BTU's needed?
Depends on window sizes, insulation, sun exposure, etc.
The sizing charts are inaccurate.
This being said, 5-6k btu/hr is more than enough for most medium to large rooms.
To cool an entire floor of a house, more like 8 to 12k.
May need a fan to distribute the air and stop it from short cycling due to cooled air being pulled back into the unit. Another option is a unit with a remote thermostat - danby calls the feature "follow me".
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is offline   Reply With Quote
Old 05-09-2020, 03:27 PM   #5
Rewards Points: 40
Thanks a lot. I’ve heard more powerful is not really always better. I guess as long as it cools us down, it’s good
Old 05-09-2020, 03:39 PM   #6
Rewards Points: 238
It was common for the post wwll 2 bedroom house to be 24 x 48. A 1 ton window unit was heavy as hell and did a good job for the whole house. The room doors remained open in those days. It was also common for those to run iced with no air flow from about 4 am until turned off when the rooster crowed and woke everyone up around 6 am.
SeniorSitizen is offline   Reply With Quote
