Why 3 Transfer Grilles On Furnace Room Wall. Also Do I Need A Cold Air Return? - HVAC - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Rolin
Old 05-30-2020, 12:14 AM   #1
Rewards Points: 58
Why 3 Transfer Grilles on Furnace Room Wall. Also do I need a cold air return?
Hi, I'm remodeling my basement and noticed the previous owner had 3 transfer grilles on the furnace room wall. I assume it's for better air flow to the furnace. But several years ago when I had a water heater replaced, they installed a duct leading from outside to the furnace room (I believe it's called a combustion air duct?). My question is whether these 3 transfer grilles are needed - 0,1, 2 or all 3?
I was also wondering if I need a cold air return in this basement. There are no doors - just an open stairway leading to the cold air return upstairs? I'm considering converting one of the transfer grille to a cold air return if needed - although hoping I don't need to do the extra work if not needed!
Why 3 Transfer Grilles on Furnace Room Wall. Also do I need a cold air return?-img_0186.jpg
Rolin is offline   Reply With Quote
Old 05-30-2020, 06:35 AM   #2
Rewards Points: 92
Re: Why 3 Transfer Grilles on Furnace Room Wall. Also do I need a cold air return?
Both the water heater and the furnace may have combustion air needs. Since we have no idea what units you have and other details it is hard to advise. I'm not a hvac pro but work with energy functions and we avoid starving any appliance for combustion air, it can cause backdrafting of either one. Since the water heater has the least need I wouldn't conclude that outside air supply will serve both.
Some pictures might help and include the new outside air supply.
pros will be along.
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is online now   Reply With Quote
Old 05-30-2020, 11:19 AM   #3
Rewards Points: 58
Here are pics. The furnace is old - will be replaced I suspect in a few years. The door for this furnace room is a bifold, so it does not seal the room off as much as a standard door.
BTW: the pics are not rotated correctly in this forums but they are correct on my PC. Not sure how to fix.
Why 3 Transfer Grilles on Furnace Room Wall. Also do I need a cold air return?-img_0187.jpg   Why 3 Transfer Grilles on Furnace Room Wall. Also do I need a cold air return?-img_0188.jpg   Why 3 Transfer Grilles on Furnace Room Wall. Also do I need a cold air return?-img_0189.jpg   Why 3 Transfer Grilles on Furnace Room Wall. Also do I need a cold air return?-img_0190.jpg
Old 05-30-2020, 12:44 PM   #4
surferdude2's Avatar
Rewards Points: 896
The safest decision is to leave them alone. If you must get rid of them, I recommend getting a louvered door to replace the bifold. I'd probably do that anyway. Those methods are more reliable than an outside air duct run. That's a large water heater and if you have 60k or 80k of furnace demand to add to that, it's best to not risk choking it.
I recommend installing an air return in the basement. Down low is where I like them but up high is better than nothing. Even with an open door to upstairs, the basement air flow is never adequate without a RA of its own. It'll smell like a basement without one so that's the tip off.
Ah, but I was so much older then...I'm younger than that now
surferdude2 is offline   Reply With Quote
Old 05-31-2020, 06:33 AM   #5
An old Tradesmen
Rewards Points: 50
Looks like combustion air intakes for the furnace.
Old 05-31-2020, 07:09 PM   #6
Rewards Points: 5,094
For heating you should install returns. Otherwise the heat will hug the ceiling and find its way upstairs, leaving your cellar cold.
Old Thomas is offline   Reply With Quote
Old 05-31-2020, 07:34 PM   #7
user_12345a's Avatar
Rewards Points: 36
leave the grills alone, definitely add return air to the basement.
You should really have the heat exchanger in that old furnace checked, if it's 20+ years old very good chance it's cracked.
Best to go with sealed combustion 90%+ when replacing.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is offline   Reply With Quote
Old 05-31-2020, 11:15 PM   #8
Rewards Points: 58
Thanks for the replies.
Here's my plan. I will leave the upper and lower right transfer vents alone- along with the more recently added fresh air combustion duct in the furnace room, that should be enough for the furnace and water heater. I'll convert the lower left transfer vent to a cold air return for the basement family room
Sound good?
User_12345, I had the furnace checked last summer - no cracks. But will be replacing in the next couple of years anyway - I believe it's from the early 90's.
surferdude2 likes this.
Old 06-01-2020, 08:56 PM   #9
Rewards Points: 896
I just have to add:
A CO and smoke detector is an excellent safety measure for basements with gas consuming devices operating, especially if there will be people sleeping in there. Code also has egress requirement that you should review, especially if it's not a walk-out basement and also if you intend to partition off any rooms, each must have egress windows.
