White "powder" - HVAC - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By user_12345a
Old 01-23-2020, 07:40 AM   #1
white "powder"
I have a white powdery substance collecting on my furnace filter. It is a MERV 5 filter and only lasts about 10 days. There has been no drywall work done for several years. Does any body have any idea what this could be?
artprice is offline   Reply With Quote
Old 01-23-2020, 09:38 AM   #2
Rewards Points: 1,186
Re: white "powder"
If you’re located in a climate where indoor air gets dry in the winter, and there is a humidifier upstream of the filter, the white particles may be mineral deposits left behind by evaporating water. A properly running humidifier should be putting only water vapour into the air, leaving the mineral deposits behind in the unit. A malfunctioning unit may be putting liquid water into the air stream, along with the minerals dissolved in the liquid.
Chris
Chris616 is offline   Reply With Quote
Old 01-23-2020, 10:01 AM   #3
Usually Confused
lenaitch's Avatar
Rewards Points: 74
Re: white "powder"
If you have a humidifier upstream it could be mineralization precipitating out of the water. Otherwise, it could be dust, dry skin, etc. in the dry household air during the winter.
_________________________________
Parati vero parati
lenaitch is offline   Reply With Quote
Old 01-23-2020, 10:22 AM   #4
user_12345a's Avatar
Rewards Points: 52
Re: white "powder"
Only the ultra-sonic style mist humidifiers can do that - evaporation humidifiers don't put out minerals.
lenaitch likes this.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is offline   Reply With Quote
Old 01-23-2020, 10:23 AM   #5
surferdude2's Avatar
Rewards Points: 902
Re: white "powder"
That problem is a common one when using an atomizing (mist spraying) type of humidifier rather than an evaporating type. How serious it is varies with how much mineral content is in your water supply.
I suggest you get an evaporative type of humidifier since the furnace filter isn't getting all those solids from the air and breathing that stuff may not be healthy.
Ah, but I was so much older then...I'm younger than that now
surferdude2 is offline   Reply With Quote
Old 01-23-2020, 10:46 AM   #6
Re: white "powder"
I didn’t know that furnace mounted atomizing type humidifiers were available. I recall we bought one of the standalone types for a single room but we only used it for a short while before we recognized why every horizontal surface in the room was turning white.
Chris
